temp that horton fan should kick in ?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by AUSSIE DAVE, Mar 21, 2011.
  1. AUSSIE DAVE
    AUSSIE DAVE Road Train Member
    1,032
    176
    Feb 21, 2010
    OZ - Brisbane
    Hi all need some help, my horton fan only seems to kick in after the temp gauge goes into the red section (kenworth with a M11).
    Also does anyone know why this would be happening?
    And is it possible to have cummins adjust it so it kicks in at a temp that is in the green section?
    I did buy a new fan sensor, could cummins have sold me the wrong one?
  3. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    About 93 dgr c. This parameter is not changeble with dealer Insite software.
    AUSSIE DAVE Thanks this.
  4. Nevs
    Nevs Light Load Member
    295
    107
    Dec 25, 2010
    flyover country (Iowa)
    Not sure on a Cummins,but my Cat turns on at 215* F. Turns back off at 208* F.
  5. Heavyd
    Heavyd Road Train Member
    7,756
    6,195
    Feb 4, 2009
    Cummins are around 207 F to 210 F depending on what year you have. This is not adjustable. What is the temperature range of your green zone in your gauge?
  6. AUSSIE DAVE
    1,032
    176
    Feb 21, 2010
    OZ - Brisbane
    approx 176f to 212f, (80c to 100c)
  7. Heavyd
    7,756
    6,195
    Feb 4, 2009
    Ok, first we need to know if your truck is getting the same signal for the coolant temp as the ecm or does the gauge have it's own separate sensor. Then you need to check what the ecm is actually reading for coolant temp and again compare with the gauge. You may need an infra red thermometer to check true engine temp. Even though the gauge says 230, the engine may only be at 205. Cummins recommends coolant no hotter than 212 F for a M11. The CEL will come on and set a code and derate your engine at 219 F.
  8. AUSSIE DAVE
    1,032
    176
    Feb 21, 2010
    OZ - Brisbane
    I checked the fan sensor wires and found they appeared in good order so moved onto inspecting the connector to the fan sensor and that appeared ok, the good news is that since disconnecting and reconnecting the fan sensor plug/connector the fan is now kicking in at around 95c YIPPY. Im guessing there was a bit of dirt / ##### on the pins or connector.
  9. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    have you got ECT fault code?
  10. AUSSIE DAVE
    1,032
    176
    Feb 21, 2010
    OZ - Brisbane
    No fault codes, I checked for codes today.
  11. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    so worry about nothing. keep driving.
