Temperature control 389
Discussion in 'Peterbilt Forum' started by UStrucker, Dec 10, 2016.
  1. UStrucker
    UStrucker Bobtail Member
    45
    59
    Feb 18, 2013
    Los Angeles,CA
    I have a 2008 peterbilt 389 and the temperature control switcher is not working(windshield to feet and to the cab)it is in only one position.Anyone know what could be the problem is?
  3. Pnwtrucker
    Pnwtrucker Medium Load Member
    383
    821
    Nov 5, 2016
    Actuator in dash. Under the glove compartment if you remove that plastic piece 3 actuator motors. Fan speed, temp and direction. Don't remember which is which but it's simple fix. Remove the panel and you'll see them. Could be the door that actuator moves is sticky or stuck too but likely the actuator itself.
    UStrucker Thanks this.
  4. UStrucker
    45
    59
    Feb 18, 2013
    Los Angeles,CA
