Test Thursday!! Question.
Discussion in 'Questions From New Drivers' started by chefy79, Mar 16, 2011.
  1. chefy79
    chefy79 Bobtail Member
    49
    Dec 1, 2010
    chicago il
    ok when doing the air brake test lets say the test your tractor parking brake test ok air normal 100-125 psi i want to keep my tractor brakes applied releasing the trailer emergency brakes put the tractor in first gear and give it a tug. ok heres where i am stumped do i put it back in neutrul then apply the trailer brakes to keep it secure or do i still leave it in 1st gear and apply the trailer brakes?? i just dont want to get a fail because of a unsercure truck. let me know. thanks
  3. Cudascious
    Cudascious Medium Load Member
    350
    148
    Feb 25, 2011
    New Mexico
    I engaged the clutch, put it in neutral and then activated/tested brakes by putting it in gear during the test with the examiner. I am pretty sure i could have just left it in gear with the clutch fully depressed activating the clutch brake. Best thing to do is find out what the examiner prefers. Who is teaching you?
  4. Okieron
    Okieron Crusty Okie
    1,641
    1,024
    Dec 23, 2009
    muskogee, ok
    how ever you do it keep pedal brakes on until parking brakes are on.
  5. Cudascious
    350
    148
    Feb 25, 2011
    New Mexico
    I didn't hold the pedal brake down because I was on level ground, well actually I probably did when both spring brakes were released, I think. I was pretty nervous and cant recall much. lol
    I'm pretty sure I only used the service brake to fan the air tanks down to test the low air alarm and get the spring brakes to activate at 20-40 psi. Then started it up and built up the pressure and performed the trailer/tractor/application pressure loss tests and lastly the service brake test. Not sure if I did it exactly right, but got 100% on the in cab tests, whew. I believe the air brake test is the one test that if you don't get it right its an instant fail. That and no hitting curbs or shifting over RR tracks.
    Are you going to a school or taking it on your own?
  6. msfern29
    msfern29 Light Load Member
    180
    39
    Sep 23, 2010
    SW Kansas
    the school taught me, if the parking break and / or emergency breaks are on, no reason to have your foot on the break peddle. your breaks are engaged. cover break peddle during the air breaks test, but don't push on it.
    I talked my way thru it. "now going to test emergency breaks on trailer, cover break peddle, releasing tractor parking break, fully engage clutch, low gear, ease on clutch, tug a bit on breaks, and yes they hold, fully engage clutch, back to neutral and need to test the parking breaks...." I'm sure was annoying to the examiner fellow having to hear step by step, but worked great for me.
