testing air compressor
Discussion in 'Trucks [ Eighteen Wheelers ]' started by cumminsISB, Aug 1, 2014.
  1. cumminsISB
    cumminsISB Light Load Member
    176
    10
    Feb 5, 2011
    D'Lo, Ms
    Was wondering how do disconnect the air compressor to see if it is the cause of compression in coolant system. If I disconnect the coolant to the air compressor I will lose coolant and the compressor will not be cooled...right? if I disconnect air it will still be pumping air into coolant? Confused on how to see if the compressor is bad before I tear into the engine. By the way 2001 w900 caterpillar c15 6nz
  3. JohnP3
    JohnP3 Road Train Member
    1,594
    684
    Feb 21, 2010
    Rock Creek B.C. Canada
    Look at the compressor, there is no fluid in the base of the compressor, so the head gasket is not involved. What I did was put shop air into the compressor out let. if it did not blow bubbles that is not the problem. you could also go the Diesel garage site and under the search section enter handy links, and go down until you find the bottle test. Do the complete test and you will know what the problem is. I wrote it.
    Just a thought!
  4. cumminsISB
    176
    10
    Feb 5, 2011
    D'Lo, Ms
    did some testing today. bubbles with air compressor connected and disconnected. funny thing is the overflow tube can't be more than about a 1/4 inch into the water any further down and it does not blow bubbles? posted a you tube video called "bubbles" link is below. that was with the engine at operating temp and idling. also noticed steam coming out of overflow tube when pulled out of water. Coolant hoses hard? A lot of pressure on radiator cap, blew out a lot of coolant when I loosened cap. also noticed some gurgling bubbling noise coming from back of water pump after truck was shutdown. Would water pump or thermostats cause compression in coolant system they are bad? http://youtu.be/ZZaKPTMPr-A
  5. Tmtbob
    Tmtbob Medium Load Member
    303
    186
    Mar 3, 2014
    Oklahoma
    Idle it up to 1500 with the hose at the bottom of the bottle and compressor unhooked and see if it blows like I think it will. Sounds like head gasket. Water pump won't build pressure
  6. cumminsISB
    176
    10
    Feb 5, 2011
    D'Lo, Ms
    same thing...at 1400 rpm top speed cruise will set. Bubbles only when bottle is turned sideways a little or hose is about 1/4 to 1/2 deep in water never with bottle straight up and down. No sludge/water in/on oil cap or blowby tube from valve cover. One thing I did notice was once I turned cruise off and brought truck back down to idle that is when the coolant comes out of the overflow hose and cap. Put a new cap on also. I am confused. Could a water line being plugged cause this. Really grasping now, do not want to tear into this engine without be absolutely sure.
  7. Tmtbob
    303
    186
    Mar 3, 2014
    Oklahoma
    Find some more tests to do till you are convinced. If you did all that with compressor unhooked then there is no where else it could be coming from. Water pump will not build pressure. It just moves the water so there is no way a plugged hose would do that. More than likely it's a bad head gasket. Could be just a bad gasket or worse it could be worn block or head
