Testing Out?
Discussion in 'Swift' started by robbiecox6, Aug 30, 2013.
It means that upon success, they then assign you to a truck and you're on your way. Solo.
All it is is a skills test. - Cheers. -
newtruckerwife84 Thanks this.
It means that your mentor has cleared you to go solo, and you do a road test and a short written test.
The road test is basically the same driving test you did in orientation. You drive around the block and do a couple backs in the yard.
The written is just as easy.newtruckerwife84 and robbiecox6 Thank this. -
After testing out you are then assigned a truck. That can take a day or so, and if you are at your home terminal they may be reticent to put you up in a hotel. That happened to me, and it would have been a major pain to get home by bus. I pushed and suddenly they had a truck available. I slept in my truck that night while waiting for my first dispatch.
newtruckerwife84 and fr8te_sh8ker Thank this. -
I didnt have to do a written to test out, I did a "mid term" written where you explain the macros and show you can follow a route and atlas etc, when I tested out I drove around a block then did a single backing
