Hello everyone ! Thanks in advance for your advice !
I plan on buying a truck and leasing on to a company at West Texas oilfields to haul frac sand .
I'm a company driver now at south Texas oil fields getting my experience in this field .
From what I see and hear the level of dust and bad road conditions is even worse at west Texas than here at south . But there is more consistent work at west Texas .
Do you guys have any experience and/or recommendations about :
- What truck to buy to do work in those conditions ? ( Brands , models , newer , older ? )
- What extra maintenance I should do ? ( I know definitely clean and change air filters often , grease the truck more often , checking loose nuts and bolts more often )
- Do you know any good companies to lease on to at west Texas ? ( I got only 1.5 years of driving exp so so far I found only one company I could lease on to which is 1845.com )
- Do you have any other suggestions or advice ?
Thank you and hopefully this topic will be helpful to others going in to oil fields of Texas as well
Texas Oil fields - Trucks and maintenance in dusty environment + rough roads
Discussion in 'Questions From New Drivers' started by Dominik Skupina, Jul 27, 2018.
Page 1 of 3
It depends on whom you ask about what truck is best. I've seen western stars hold up quite well. But some ppl are fans of Petes or kw or what ever brand. 1845 is ok to lease on with and there supposedly the largest company in frac sand hauling. But once again it depends on who you ask. The company drivers at 1845 tend to quit often, or get fired.
The mechanics in our company shop mentioned that Volvo trucks are holding quite well over here but the company is ordering only new KW's so who knows ...
1845 the largest ? thats interesting ! Do you know if they hire the company drivers in to their company trucks or they put them in to an O/Ops trucks ? -
From what I've seen the most common truck damage is where the hood meets the cab. From my experience a 389 Pete does great, as well as the t800 and t660. I like their rubber cone in the pocket type design on the hood. No experience on a w900l.
Lepton1 Thanks this. -
In my years in the New Mexico high plains I drove KWs, "Fright"liner and a 10 year-old Mack. The Mack took the abuse pretty well. KW were so-so. "Fright"liner" is self-explanatory. But it's been a while, I left in 2011.
TheyCallMeDave and Lepton1 Thank this. -
High ground clearance and metal body parts are very high on my list of must haves for doing what you want to do. Having a shiny bumper with chicken lights scraping the ground will get destroyed.
Make sure you have beefy tow hooks. You never know when you will need a fellow driver or bulldozer to haul your ### out of sand, mud, or snow.
I run flatbed out of OKC. We frequently get loads to West Texas and SE New Mexico. Those caliche roads are brutal. Impatient drivers leave truck parts all over the road. The paved roads can be worse (Orla Road takes the cake in my experience).
I'm putting feelers out for my next truck. Western Star is high on my list, but Peterbilt is in the running. The drive train will be pre emissions. They're pricey.
There's lots of cheap plastic trucks in the oil field. If it's in good shape there's less than three bungies holding the bumper on (if it has a bumper).SavageMuffin, austinmike, x1Heavy and 1 other person Thank this. -
we've been in business in the northern Alberta/Saskatchewan/BC oil patch for 51 years. we run Kenworths exclusively, as do most of the other heavy haul companies that have been around for any length of time up here. Peterbilt and Western Stars are the next most common.
if you can score a well spec'd pre emissions KW you would do ok. they are getting hard to find and demand a good dollar. -
Pretty much everything @Lepton1 said. Take it slow on the lease roads and stuff will last longer.
There’s so many companies popping up in the frac sand biz these days I don’t even know where to start. Look for one that’s been around a while under the same name.Lepton1 and Dave_in_AZ Thank this.
Page 1 of 3
