Texas star 450
Discussion in 'CB Radio Forum' started by bigdogpile, Feb 28, 2015.
  1. bigdogpile
    bigdogpile Road Train Member
    1,931
    1,463
    May 16, 2010
    fontana ca
    When I key up the mic all my dash and internal lights go dim..whats going on? It is hard wired to the battery and I was told I will "stress" out the ALT if I continue..
  3. Powder Joints
    7,939
    8,275
    Sep 25, 2007
    Rosamond, SoCal
    Your truck is not suppling enough current to run the amp, as to why that is I can not say without seeing the truck, So is the truck more important than the amp, dont use it till a mechanic finds the problem.
    Could be as little as a bad or missing ground cable, could be as much as bad alt and batteries. Can not diagnose over the internet.
  4. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    What Powder Joints said...Your alternator's not putting out enough to run the Amp+the vehicle...
    2 things you can do...either get a alternator that put's out more amperage, OR add another battery.
    With all the cold weather, it also could be the battery you have is on it's last-leg...Be sure you have a good hot battery to start with.
  5. bigdogpile
    1,931
    1,463
    May 16, 2010
    fontana ca
    Alright thanks guys, I'll check the batteries life..
