That pass thru thingy on firewall on my Volvo.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by me myself and I, Sep 9, 2012.
  1. me myself and I
    me myself and I Heavy Load Member
    732
    312
    Oct 5, 2009
    vernon hills,Il
    Had anybody replaced it? How difficult was it? I had one leak repaired (for $100), and now another leak. I got those rubber seals hoping to fix it myself, but I have no idea how to do it.
  3. Cummins600
    Cummins600 Bobtail Member
    26
    8
    May 18, 2011
    Pa
    Are you talking about those bulkhead fittings in the firewall? If so, they are not bad to change at all. If it is leaking outside in the engine compartment, just unscrew the old half of the fitting and screw the new piece on that and you should be good. If it's leaking inside the cab, you have to take the plastic piece out closest to the door. It is easier to take the bottom bolt out of the grab handle and push the the tilt wheel down when you're ready for it to come out. Hope this helps.
  4. jardel
    jardel Light Load Member
    110
    21
    Mar 8, 2009
    BUFORD,GA
    yea i replace mine is not difficult just make sure you reed those numbers on the new one because the new part has been change you have to swap some of them.even the new one will leak a little .
  5. maxicruise
    maxicruise Light Load Member
    58
    19
    Aug 11, 2010
    Illinois
    We have changed a few of them. You will need some skills, and you need to write down where things are because some of the lines go in a different location. Don't try to go on memory. It helps to have two people too.
  6. me myself and I
    732
    312
    Oct 5, 2009
    vernon hills,Il
    I've replaced rubber ring on leaking fitting and it doesnt leak..of course while I was working on it, i've heard another air leak. This one is by the engine, inside frame. I love my truck :(
