Thats not 6th gear...
Discussion in 'Experienced Truckers' Advice' started by jjoohhnn, Sep 15, 2015.
  1. jjoohhnn
    jjoohhnn Bobtail Member
    44
    17
    Jun 20, 2015
    I'm running a new frieghtliner cascadia 10speed.
    All the gears are good except for one....
    When I flip my selector, and go from 5th to 6th, it'll go into gear... But my trucks in neutral still?
    I take it out of gear, and put it back into 6th, and it'll catch finally.
    This happens maybe 1 out of 5 times. Anyone know what's going on?
    Vilhiem Thanks this.
  3. Cottonmouth85
    Cottonmouth85 Bad Influence
    2,637
    8,701
    May 3, 2012
    Floresville, Tx
    Shifting too fast?
    Ruthless Thanks this.
  4. rbrtwbstr
    rbrtwbstr Road Train Member
    3,391
    7,867
    Jul 11, 2012
    in the bush somewhere
    Splitter valve sticking?
  5. jjoohhnn
    44
    17
    Jun 20, 2015
    That's what I was wondering. I flick my selector as I take it out of fifth and immediately have it at the door of 6th. Probably not giving it enough time to engage. Nothings sticking. But I figured if it was me doing it too fast the truck would assume I meant for 1st gear. It doesn't rev up hard on me when it happens tho. Just neutral.
  6. Cottonmouth85
    2,637
    8,701
    May 3, 2012
    Floresville, Tx
    Sounds like you're catching it on the split. Try being less aggressive.
    truckon and Straight Stacks Thank this.
  7. Straight Stacks
    Straight Stacks Paper Cha$er
    2,930
    20,768
    Jul 18, 2015
    Alabama Gulf Coast
    I agree with @Cottonmouth85...if you are less aggressive and make yourself less interested/available, 6th gear will be more attracted to you.
    n3ss, fr8monkey, HorseShoe and 8 others Thank this.
  8. jjoohhnn
    44
    17
    Jun 20, 2015
    She's nothing like my last 6th gear. It'll take time to learn to finesse her. But Thx for the relationship tips
  9. fargonaz
    fargonaz Road Train Member
    1,167
    4,583
    Feb 9, 2015
    Mesa, AZ
    On this eaton 10, her 6th is tight, you have to pre-select upper and then jam it in quick or she looses interest.
  10. Cottonmouth85
    2,637
    8,701
    May 3, 2012
    Floresville, Tx
    Lol
    You can't just jam it in. They don't appreciate that. You need to be gentle when you put it in'er six holem
    fargonaz and truckon Thank this.
  11. R.Rodriguez
    R.Rodriguez Light Load Member
    111
    34
    Aug 20, 2010
    Port Hueneme, CA
    Pre-select high range while in fifth and then make the shift to sixth. This should give it plenty of time. It's ok to pre-select the range, but not the split on a 13, 15, or 18 speed.
    Pullin2 Thanks this.
