The chains that bind me.
Discussion in 'Questions From New Drivers' started by MikeMc, Feb 23, 2008.
  1. MikeMc
    MikeMc Bobtail Member
    12
    Jan 23, 2008
    S.E. Indiana
    What is DOT regulation on chain sizes with hauling steel coils? 5/16 or 3/8"? Is it still one chain per 10,000 lbs?
  3. rookietrucker
    rookietrucker Trucker Forum STAFF Staff Member
    10,061
    7,055
    Jul 15, 2007
    TEXAS
    <DIV>§ 393.120 What are the rules for securing metal coils?
    (a) Applicability. The rules in this section apply to the transportation of one or more metal coils which, individually or grouped together, weigh 2268 kg (5000 pounds) or more. Shipments of metal coils that weigh less than 2268 kg (5000 pounds) may be secured in accordance with the provisions of §§ 393.100 through 393.114.
    (b) Securement of coils transported with eyes vertical on a flatbed vehicle, in a sided vehicle or intermodal container with anchor points-(1) An individual coil. Each coil must be secured by tiedowns arranged in a manner to prevent the coils from tipping in the forward, rearward, and lateral directions. The restraint system must include the following:
    (b)(1)(i) At least one tiedown attached diagonally from the left side of the vehicle or intermodal container (near the forwardmost part of the coil), across the eye of the coil, to the right side of the vehicle or intermodal container (near the rearmost part of the coil);
    (b)(1)(ii) At least one tiedown attached diagonally from the right side of the vehicle or intermodal container (near the forwardmost part of the coil), across the eye of the coil, to the left side of the vehicle or intermodal container (near the rearmost part of the coil);
    (b)(1)(iii) At least one tiedown attached transversely over the eye of the coil; and
    (b)(1)(iv) Either blocking and bracing, friction mats or tiedowns must be used to prevent longitudinal movement in the forward direction.
    (b)(2) Coils grouped in rows. When coils are grouped and loaded side by side in a transverse or longitudinal row, the each row of coils must be secured by the following:
    (b)(2)(i) At least one tiedown attached to the front of the row of coils, restraining against forward motion, and whenever practicable, making an angle no more than 45 degrees with the floor of the vehicle or intermodal container when viewed from the side of the vehicle or container;
    (b)(2)(ii) At least one tiedown attached to the rear of the row of coils, restraining against rearward motion, and whenever practicable, making an angle no more than 45 degrees with the floor of the vehicle or intermodal container when viewed from the side of the vehicle or container;
    (b)(2)(iii) At least one tiedown over the top of each coil or transverse row of coils, restraining against vertical motion. Tiedowns going over the top of a coil(s) must be as close as practicable to the eye of the coil and positioned to prevent the tiedown from slipping or becoming unintentionally unfastened while the vehicle is in transit; and
    (b)(2)(iv) Tiedowns must be arranged to prevent shifting or tipping in the forward, rearward and lateral directions.
    (c) Securement of coils transported with eyes crosswise on a flatbed vehicle, in a sided vehicle or intermodal container with anchor points-(1) An individual coil. Each coil must be secured by the following:
    (c)(1)(i) A means (e.g., timbers, chocks or wedges, a cradle, etc.) to prevent the coil from rolling. The means of preventing rolling must support the coil off the deck, and must not be capable of becoming unintentionally unfastened or loose while the vehicle is in transit. If timbers, chocks or wedges are used, they must be held in place by coil bunks or similar devices to prevent them from coming loose. The use of nailed blocking or cleats as the sole means to secure timbers, chocks or wedges, or a nailed wood cradle, is prohibited;
    (c)(1)(ii) At least one tiedown through its eye, restricting against forward motion, and whenever practicable, making an angle no more than 45 degrees with the floor of the vehicle or intermodal container when viewed from the side of the vehicle or container; and
    (c)(1)(iii) At least one tiedown through its eye, restricting against rearward motion, and whenever practicable, making an angle no more than 45 degrees with the floor of the vehicle or intermodal container when viewed from the side of the vehicle or container.
    (c)(2) Prohibition on crossing of tiedowns when coils are transported with eyes crosswise. Attaching tiedowns diagonally through the eye of a coil to form an X-pattern when viewed from above the vehicle is prohibited.
    (d) Securement of coils transported with eyes lengthwise on a flatbed vehicle, in a sided vehicle or intermodal container with anchor points-(1) An individual coil-option 1. Each coil must be secured by:
    (d)(1)(i) A means (e.g., timbers, chocks or wedges, a cradle, etc.) to prevent the coil from rolling. The means of preventing rolling must support the coil off the deck, and must not be capable of becoming unintentionally unfastened or loose while the vehicle is in transit. If timbers, chocks or wedges are used, they must be held in place by coil bunks or similar devices to prevent them from coming loose. The use of nailed blocking or cleats as the sole means to secure timbers, chocks or wedges, or a nailed wood cradle, is prohibited;
    (d)(1)(ii) At least one tiedown attached diagonally through its eye from the left side of the vehicle or intermodal container (near the forward- most part of the coil), to the right side of the vehicle or intermodal container (near the rearmost part of the coil), making an angle no more than 45 degrees, whenever practicable, with the floor of the vehicle or intermodal container when viewed from the side of the vehicle or container;
    (d)(1)(iii) At least one tiedown attached diagonally through its eye, from the right side of the vehicle or intermodal container (near the forward-most part of the coil), to the left side of the vehicle or intermodal container (near the rearmost part of the coil), making an angle no more than 45 degrees, whenever practicable, with the floor of the vehicle or intermodal container when viewed from the side of the vehicle or container;
    (d)(1)(iv) At least one tiedown attached transversely over the top of the coil; and
    (d)(1)(v) Either blocking, or friction mats to prevent longitudinal movement.
    (d)(2) An individual coil-option 2. Each coil must be secured by:
    (d)(2)(i) A means (e.g., timbers, chocks or wedges, a cradle, etc.) to prevent the coil from rolling. The means of preventing rolling must support the coil off the deck, and must not be capable of becoming unintentionally unfastened or loose while the vehicle is in transit. If timbers, chocks or wedges are used, they must be held in place by coil bunks or similar devices to prevent them from coming loose. The use of nailed blocking or cleats as the sole means to secure timbers, chocks or wedges, or a nailed wood cradle, is prohibited;
    (d)(2)(ii) At least one tiedown attached straight through its eye from the left side of the vehicle or intermodal container (near the forward- most part of the coil), to the left side of the vehicle or intermodal container (near the rearmost part of the coil), and, whenever practicable, making an angle no more than 45 degrees with the floor of the vehicle or intermodal container when viewed from the side of the vehicle or container;
    (d)(2)(iii) At least one tiedown attached straight through its eye, from the right side of the vehicle or intermodal container (near the forward-most part of the coil), to the right side of the vehicle or intermodal container (near the rearmost part of the coil), and whenever practicable, making an angle no more than 45 degrees with the floor of the vehicle or intermodal container when viewed from the side of the vehicle or container;
    (d)(2)(iv) At least one tiedown attached transversely over the top of the coil; and
    (d)(2)(v) Either blocking or friction mats to prevent longitudinal movement.
    (d)(3) An individual coil-option 3. Each coil must be secured by:
    (d)(3)(i) A means (e.g., timbers, chocks or wedges, a cradle, etc.) to prevent the coil from rolling. The means of preventing rolling must support the coil off the deck, and must not be capable of becoming unintentionally unfastened or loose while the vehicle is in transit. If timbers, chocks or wedges are used, they must be held in place by coil bunks or similar devices to prevent them from coming loose. The use of nailed blocking or cleats as the sole means to secure timbers, chocks or wedges, or a nailed wood cradle, is prohibited;
    (d)(3)(ii) At least one tiedown over the top of the coil, located near the forward-most part of the coil;
    (d)(3)(iii) At least one tiedown over the top of the coil located near the rearmost part of the coil; and
    (d)(3)(iv) Either blocking or friction mats to prevent longitudinal movement.he forward direction.
    (d)(4) Rows of coils. Each transverse row of coils having approximately equal outside diameters must be secured with:
    (d)(4)(i) A means (e.g., timbers, chocks or wedges, a cradle, etc.) to prevent each coil in the row of coils from rolling. The means of preventing rolling must support each coil off the deck, and must not be capable of becoming unintentionally unfastened or loose while the vehicle is in transit. If timbers, chocks or wedges are used, they must be held in place by coil bunks or similar devices to prevent them from coming loose. The use of nailed blocking or cleats as the sole means to secure timbers, chocks or wedges, or a nailed wood cradle, is prohibited;
    (d)(4)(ii) At least one tiedown over the top of each coil or transverse row, located near the forward-most part of the coil;
    (d)(4)(iii) At least one tiedown over the top of each coil or transverse row, located near the rearmost part of the coil; and
    (d)(4)(iv) Either blocking, bracing or friction mats to prevent longitudinal movement.
    (e) Securement of coils transported in a sided vehicle without anchor points or an intermodal container without anchor points. Metal coils transported in a vehicle with sides without anchor points or an intermodal container without anchor points must be loaded in a manner to prevent shifting and tipping. The coils may also be secured using a system of blocking and bracing, friction mats, tiedowns, or a combination of these to prevent any horizontal movement and tipping.
    [67 FR 61230,
  4. rookietrucker
    10,061
    7,055
    Jul 15, 2007
    TEXAS
    Sorry, it will not let me post the table here. Go to fmcsa.dot.gov website and look at table 393.108
  5. MikeMc
    12
    Jan 23, 2008
    S.E. Indiana
    Dang that was fast... Thanks!
  6. LAD_Mavric
    LAD_Mavric Light Load Member
    66
    6
    Feb 3, 2007
    Midland, ON
    I'm not sure if DOT specifies what size chain must be used but as far as the WLL goes you have to find the weakest part of your system. (Usually the pocket # 5,000lbs or the Binder # 5,000lbs. You must have enough tiedowns for 50% of the total weight of your load (steel or not)
    So if you have a chain that is good for 8,000lbs but the binder is only good for 5,000lbs then that chain is only good for 5,000lbs. Also with the 50% rule if your load weight is 40,000lbs then you need to have 20,000lbs worth of straps/chains on it.
    Therefore with a 40,000lb load of steel with WLL o your chains being 5,000lbs you would have to have at least 4 chains on it.
    Hope that was more helpfull than not.
