The Company Won't Replace My Worn Shocks
Discussion in 'Experienced Truckers' Advice' started by Blind Driver, Nov 21, 2011.
  1. Blind Driver
    Blind Driver Road Train Member
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    Suspension shocks don't work. Truck rides like a total POS. The bouncing makes my back hurt after a few hours. I didn't see anything in the DOT Regs about the shocks.
    Is this covered under inoperable equipment? Im willing to pull a shock at the scalehouse to prove my point.
    Yes, I'm looking for a new job as this isn't the only issue with this truck.
    Steering box has too much slop. I can't take my eyes off the road for half a second. No kore texting and driving for sure :biggrin_25525:
  3. blackw900
    blackw900 The Grandfather of Flatbed
    5,817
    7,678
    Jul 12, 2009
    A.W.O.L
    Shocks are not a DOT problem, Most companies do not replace shocks, In general shocks are the most neglected part of a trucks suspension....I know how you feel because I have run shocks too long a couple of times and when I finally did replace them I was amazed how bad the truck had been riding without me really noticing.
  4. Blind Driver
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    This is really frustrating. I don't want to look for another job until next year.
    $2000 would really make this 379 a really nice truck. Too bad that will never happen.
    What humors me the most is that this company is penny wise, but dollar foolish.
    They paid nearly $20k to rebuild the C15, but didnt replace the small things like the fuel return line which started leaking 3 days after the rebuild, or the coolant hoses which split 3 weeks later.
    The engine constantly overheats and the AC won't get cold. The condenser find are all bent restricting airflow. Simple fix that will never get repaired. If my new engine kept overheating, you can bet I'd fix the problem.
    I give up
  5. bokals
    bokals Bobtail Member
    30
    24
    Aug 26, 2010
    Chicago, IL
    Just tell them the shocks are eating up your tires.
  6. 123456
    123456 Road Train Member
    10,555
    5,747
    Oct 22, 2010
    32179
    I don't feel no bumps,
    in the road....................
    papa1953 and SHC Thank this.
  7. Lonesome
    Lonesome Mr. Sarcasm
    11,495
    23,774
    Dec 15, 2007
    Northern Indiana
    I believe the shocks are part of the suspension system, and as such, should be noted on the Drivers Daily Inspection Report.
  8. Blind Driver
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    There's nothing in the rules about the shocks. :biggrin_25513:
  9. PackRatTDI
    PackRatTDI Licensed to Ill
    14,765
    22,568
    Jul 15, 2006
    El Chuco, Tejas
    If there's nothing in the rules about shocks then how come that driver on that Michigan State Police video on the regulations forum got placed OOS over a broken shock?
    SHC Thanks this.
  10. Eaton18
    Eaton18 Road Train Member
    1,755
    1,104
    Sep 3, 2011
    Waverly, KS
    I think it is real strange that they can place you out of service for that. Here's what FMCSA says about PTIs;
    http://www.fmcsa.dot.gov/rules-regulations/administration/fmcsr/fmcsrruletext.aspx?reg=392.7
    http://www.fmcsa.dot.gov/rules-regulations/administration/fmcsr/fmcsrruletext.aspx?reg=393.205
    Shocks are not mentioned anywhere that I can find.
  11. Mark Kling
    Mark Kling Technology Contributor
    10,935
    4,216
    Sep 23, 2007
    Statesville, NC
    Have you called your State DOT and asked them? They will not bite.. Ask them to quote any references.
    Mark
