The diff lock light is always on, and it keeps beeping — even with the switch off.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by caucasus_a, Jun 18, 2025.
  1. caucasus_a
    caucasus_a Bobtail Member
    Hi everyone, I need some advice.
    I have a 2019 Freightliner Cascadia, and I’m having an issue with the inter-axle differential lock.
    The diff lock light stays on all the time, and I hear a continuous beeping sound — even though the switch is turned off.
    To stop the beeping and turn off the dashboard warning, I disconnected the electrical connector directly at the differential. That stopped the sound and removed the warning light from the dash.
    However, I’m not sure if the differential is actually disengaged now, or if it’s still mechanically locked.
    What could be causing this? A faulty solenoid? A stuck air actuator? A sensor issue?
    Any suggestions or similar experiences would be greatly appreciated. Thank you!
  3. Deezl Smoke
    Deezl Smoke Medium Load Member
    495
    317
    Feb 12, 2011
    Hillsboro Oregon
    Next time you are sitting for a while, drain all of the air and when you start the engine before the air builds, is the light on?
    You'll know if the pd is engaged in short distance on dry roads. And if you have axle temp gauges, watch them.
  4. mtoo
    mtoo Road Train Member
    1,935
    4,500
    Jan 15, 2011
    Retired on bended knee
    My money says the light is on with no air, those solenoid/air pressure switches go bad
    Deezl Smoke Thanks this.
  5. Deezl Smoke
    495
    317
    Feb 12, 2011
    Hillsboro Oregon
    Very possible.:thumbup:
