the empty dock slant back
Discussion in 'Experienced Truckers' Advice' started by DontaeHill, Dec 13, 2013.
  1. DontaeHill
    DontaeHill Bobtail Member
    25
    8
    Sep 5, 2013
    Im on a retail account and just having the hardest time backing. Here is what is going on can't seem to get the trailer straight Idk why but if the dock is cleared with no trucks or wall or pole I mess it up every time I do get out and look but it takes some time I never went through a wall or bumped the dock hard. 2 some of these docks are at a slight angel some what is some advice or tips on clear dock backing and angel dock backing
  3. xlsdraw
    xlsdraw Road Train Member
    4,228
    7,607
    Nov 17, 2010
    Lake Alfred, Florida
    You are not the only one. Just don't sweat it. It will get better with time. I currently drive a Prostar and I have never had such a problem backing as I do with this truck. For some reason the mirrors on this truck just don't suit me.
  4. CargoWahgo
    CargoWahgo Road Train Member
    3,912
    3,945
    Jan 10, 2012
    Louisville, Kentucky
    Set a reference point
    Hard hat works good
    Just flip on the light if its dark out.
    Don't have one?
    Lucky you... they are on sale right now at Hess or loves...just go pee....I don't remember which one
  5. Wings2Wheels
    Wings2Wheels Medium Load Member
    301
    324
    May 3, 2008
    Eastern PA
    Next time you are in a spot that has lines on both sides of the truck...like a pull through parking spot at a truck stop...make sure the truck is centered in the spot and then get in the cab.
    Look at both mirrors, and take a 'snapshot' of what the angle of the line is compared to the trailer. In your mind's eye, those two lines should be parallel...but in reality, they are not.
    Ever look down a set of railroad tracks? Wonder why they appear to converge together in the distance when you know they never do? It's called perspective. It's the way we humans comprehend things with our stereo/binocular vision.
    When you're backing without any other frame of reference, it is difficult to get that perspective right. It comes with time, but when you do the exercise with the truck perfectly in between a set of lines in the parking spot, look in the mirrors and see how the line appears farther away from the front or middle of the trailer and appears to get closer when you look at the rear of the trailer. That same 'illusion' occurs on the driver and passenger sides, so look in the mirrors and get a good idea of what the right mental picture looks like.
    Next time you're backing and there is a guide line on the driver's side, remember that you have to make the back of the trailer 'closer' to the the line than the middle and front. If you don't, the driver's side of the trailer is going to be closer to the dock than the passenger side.
    Hopefully this helps...I know it is probably about as clear as mud. Once you get that perspective down, you'll be less likely to back in crooked.
    xlsdraw Thanks this.
  6. DontaeHill
    25
    8
    Sep 5, 2013
    Thanks I thought I was the only one having this problem
  7. marineman227
    marineman227 Dock Waterer
    600
    796
    Jan 26, 2008
    Neenah, WI
    I used to have that problem and if I had to guess you're primarily if not solely using the drivers side mirror to back. When I learned to use both mirrors equally it really helped me out
  8. pattyj
    pattyj Road Train Member
    22,474
    20,137
    Jul 19, 2008
    Sioux City,ia
    I know the feeling.tyson has a few of those funny docks.All kinds of room to back but such a ####eyed angle.Keep an aye on the lines marking the dock and the sides of your trl and make sure your trl is inside those 2 lines.
  9. Mack185
    Mack185 Medium Load Member
    448
    262
    Feb 25, 2008
    The lines on the ground are crooked at half the docks I go to so they are hit or miss. Running LTL, I back into docks all day long and I back in crooked all the time, As long as the dock plate sits good, I don't care.
  10. windsmith
    windsmith Road Train Member
    7,296
    6,031
    Sep 2, 2011
    NEPA
    Look for tire tracks from the trucks that came before you. Line up with those. Don't sweat it.
