I have been around the trucking industry for 30 years. I am now General Manager for three towing companies in the Little Rock area. We have a variety of trucks from Sterlings with the mercedes MBE 900 engine Peterbuilts with Cat and Cummins engines and even a couple of Hinos. What I would like is for someone to explain what it is to run a overhead o a deisel engine and the importance of such a procedure.
the importance of running overhead adjustments on deisel engines
Discussion in 'Trucks [ Eighteen Wheelers ]' started by michael jennings, Jul 25, 2012.
Overheads adjust your valves to prevent premature leak outs of exhaust, loss of cumbustion, seal for intake, plus many other factors. Over time, your valves will stretch, the cam lobes will wear, the lifters will wear which causes tiny gaps between the valve head and the valve seat. Depending on the wear, somd engines can gain approx 20% of their power back and fuel mileage increases up to 1 mile per gallon. I've done some that only needed small adjustments and some that were drastic.
I remember one in particular that had 750,000 on N14. Other tech thought injectors were bad due to severe power loss. I did the overhead with Jake brake adjust and the difference was very noticeable. Needless to say, the injectors were fine.Ssgtkevin, Stringb8n, black_dog106 and 3 others Thank this. -
The overhead adjustment is setting the clearance between the rocker arms and the valve cross heads. As the valve and valve seat wear it allows the valve springs to pull
the valves up further as it shuts the valve which over time reduces the clearance between the rocker arm and cross head. If the overhead adjustment is ignored for long
enough the valves will no longer close entirely leading to accelerated wear in the valve train and even a burned valve. The fuel injectors are actuated by rocker arms on
most newer engines and also need to checked for proper adjustment to account for wear at the same time.Ttimefr Thanks this. -
on the acerts i was told they tighten up as they wear. if u dont keep up on the overhead u can have happen what happened to me...an intake rocker arm broke. when it went i would have swore the motor blew a rod thru the side of the block. i was told to have the overhead ran around 150,000 miles.
On the ACERT intake tightens and causes valve slapping where exhaust loosens causing combustion leakage.
Cam Roberts and Dark_Majesty_06 Thank this. -
If you got an acert your problems are much greater than overhead lolCam Roberts Thanks this.
The valve train tightens or loosens, depending on which, the last one I had done was on a 14liter 60 series, the valve train actually broke, and it was not hitting on very many cylinders, sounded like a 2 cylinder John Deere.
No codes thrown, straight mechanical failure, drove it to the nearest dealer. No further damage noted.
Leased trucks fixed at discretion of the owner. -
The valve lash pretty much tightens up on all diesel engines, when they start wearing the valve seats and or the valves themselves.
swaan Thanks this. -
How often should you get overhead adjusted?
