The #'s are not maken sence!!!
Discussion in 'CB Radio Forum' started by craig_sez, Mar 17, 2023.
  1. craig_sez
    craig_sez Road Train Member
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    Im either haven a major brain fart or something im just not seeing...
    Heres the scoop..
    + probe on center pin of coax and - on the gnd side(with antenna still attached on other end)and i get nothing on the multi meter(as if i didnt touch probes)..
    Gnd to gnd and then it reads all zeros...
    Antenna bracket itself with gnd probe and postive probe to top side of ant stud and it reads 000 for a second then goes up to approx 118 ohms...
    On tje center pin of coax to top side of antenna stud i get 2ohms but that # floats a bit cause i cant get them probs to stay in place very well..
    I do the same but with one probe on bracket and other on the threaded gnd and all zeros...
    I now move over to my analyzer and my resistence reading(r# depending on freq)goes anywhere between 42 ohms to 52 ohms but my resonance points(x#) are 5 or less off zero...
    What am i not seeing cause it seems my range is dwindleing...
    Weather here in eastern canada is still crap so not much i can do till it gets better but what in the name of god am i missing..
  3. Ridgeline
    22,457
    117,678
    What kind of stud are you using?
    Does it have a phenetic or nylon insulator?
  4. craig_sez
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    Wtf is a phenetic insulator...Its a plastic one by the way...Dont remember the brand of stud..I changed out the last one i had months ago..I need some new ones..
  5. Ridgeline
    22,457
    117,678
    The word is Phenolic, it is a resin thermoset plastic used as insulators in antennas. I have a crap load of studs with these types of insulators, they are older ones but nevertheless the nylon insulators don't hold up as well.
    The ipad keeps correcting words when I post my comments.
    Take it apart, clean it up, and put a very thing amount of silcone adhesive or sealant on all the items (Except the where the antenna mounts to the stud) to make sure they are sealed on the mount.
    It sounds like there is moisture in the mount itself.
  6. craig_sez
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    It very possible..Not touched it most of the winter..I found a new wilson stud..Ill put it on tomorrow n see...
    Im also pretty sure i got moisture down the riser where my whip goes into it..Its all siezed up to..To much of a rush when i installed and no anti sieze on the set screw and didnt seal it where whip slides in..To much of a kid in me rushed it..
    Tomorrow is supped to be decient but also supped to get rain,see if i can get something done between rain drops..
  7. Ridgeline
    22,457
    117,678
    Do you have a hair dryer and power for it?
    Try slowely and carefully heating the stud above the mount and antenna up and see what happens.
  8. Night Stalker10
    Night Stalker10 Road Train Member
    1,683
    1,257
    Jun 26, 2017
    Since it's still winter weather and it looks like salt on your truck and antenna (or it's just muddy water from the road), it looks like you do have a corrosion problem. That would definitely cause the numbers to change.
    rabbiporkchop Thanks this.
  9. Night Stalker10
    1,683
    1,257
    Jun 26, 2017
    Craig, on second thought, maybe if you wash your truck, the numbers will go back to normal. Ha ha.
