The sleep apnea scam
Discussion in 'Swift' started by ltwombat, Aug 5, 2012.
  1. ltwombat
    ltwombat Light Load Member
    176
    85
    Jun 2, 2012
    Las Vegas, NV
    I have read several threads on here in other forums about drivers being rejected, fired or other sanctions because their neck size is over 17" or their BMI (body mass index) is over 38 as they are candidates for sleep apnea.
    Recruiter sent me to Concentra in Bakersfield for my pre academy DOT physical. This is my seciond attempt because the first doc (different place) felt I should be on insulin for a HGBa1cof 6. My V.A. Endocronologist team said he nuts so my primary doc filed an exception form for me with the DOT and that issue should be resolved in 3-5 weeks.
    Go to the new place, fill out long form, pay $75 and wait for 2 hours to be taken in the back. Pass Blood pressure, pee test, drug test, vision and hearing test. When I get to the exam room the med asst. measures my neck and when I am over 17 she says, "you're gonna get rejected for a sleep study" then leaves. 45 min later doc comes in. First words out of his mouth are, "your BMI is over 38 and your neck is over 17" so I can't give you a physical until you get a sleep study done. But don't worry, I have a friend (hands me business card) who can help you today and you'll be done for $1,200 for the test and $1,000 for a cpap machine. He takes all credit cards or can sign you up for credit today".
    I hand the card back and say I have already had a sleep study at the VA and own a cpap machine. He says, "ok then I need the sleep study, but it can't be over 90 days old, plus a years worth of data downloaded from your machine plus a letter from your doctor stating you are cpap compliant and free of apnea when using cpap". I tell him my sleep study was in March so he hands me back the card and says again his friend can have me done and passed today then he leaves. When the med asst. comes in to discharge me I asked her about the sleep apnea stuff and she said it is the company asking for the apnea clearance not the DOT.
    So I leave once more empty handed. The VA is backed up for 3 months on sleep studies because they seem to be in vogue these days. Guess I won't be seeing you guys on the road any time soon. I have an email into my recruiter asking if this is a Swift rule or am I being shaken down for $2,200 but since I sent it late Friday I probably won't get an answer until Tuesday, if she will even broach the subject.
  3. Shaggy76
    Shaggy76 Heavy Load Member
    831
    307
    Feb 22, 2012
    Orlando, FL
    There is no DOT rule on Sleep Apnea. Doctors that work with these facilities are making some big bucks for something not proven and still being studied. Companies are giving no leeway and once a doctor says you have it, physical has to be done every year as well as a sleep study. So expect to pay 1200 every single year in order to get your physical passed. It is exactly why people are leaving this industry by the hundreds every day and companies are struggling to keep drivers more so than before.
  4. otherhalftw
    otherhalftw R.I.P.
    13,081
    45,332
    Nov 18, 2008
    CA...gold discovery foothills
    While there is no rule or regulation..it is being addressed by the FMCSA....http://www.fmcsa.dot.gov/safety-security/sleep-apnea/tools/fact-sheet.aspx
    so...when they are "looking into it"....especially the mega carriers will be trying to get a "good report" by "adhering to the potential rule"...even though there isn't one presently!
  5. kwayne88
    kwayne88 Light Load Member
    50
    15
    Jun 3, 2012
    Leesville, La.
    Sounds like a scam to me.
    I have known four guys in my life that would drop off to sleep if they sat for more than a couple of minutes. All of them have small pencil necks and only one had a BMI over 30, and that had come about with in the previous few years although he had the sleeping problem for twenty years.
    I have had a neck larger than 17 inches and my BMI is pretty high and I can't go to sleep without relaxing for a couple hours, even if I have been up for over twenty hours straight.
  6. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,733
    Apr 18, 2010
    Tennessee
    A1c of 6 is normal. I don't know what that doc is thinking? Anything above 7 and you are type 2 diabetic. Only with uncontrolled readings higher than that when treated with pills than they consider insulin. If it's the VA the lab work shows on the paperwork the scale range.
    Sleep studies are crooked. So is the whole medical system with buddy referrals and overpricing. My sleep study ended up costing me twice what they told me. I paid $2000 for my Cpap and you can buy the same new one off the internet for $700. They also forced me to rent to own for 13 months. Why 13 months, why not 12? Why not buy out right since I'll need it the rest of my life? The only thing I could figure out is they wanted to get me for two yearly deductibles as it was set up with BCBS. The doctor said the insurance company required it. The insurance company said the doctor required it. One of them if not both were lying.
    What you are going through is a company thing. DOT has not yet started enforcing sleep studies. There are too many truckers that have sleep apnea. An estimated one third have it. That's a heck a lot of drivers to start testing and rejecting.
    I read in my researching that sleep apnea if left untreated leads to diabetes and hypothyroidism. I have all three. If you haven't already, have your thyroid checked. On your VA blood work it will be labeled "TSH". There are different thoughts on levels but it should be less than 4, more like 1.0. Any numbers higher and you need Levothyroxin. If you are seeing an Endocronologist they should already be aware of your numbers.
    I go to a small contracted out VA clinic which refers you to a VA hospital 150 miles away. The nurse practitioner I had was a quack. She had numerous complaints and quit three weeks ago without notice. The VA had no choice but to temporarily shut down the clinic. I'm left in limbo right now until they figure something out. I had a nuclear stress test Friday and have no one to read the results. :) I'm going to call the cardiologist directly and I hope he can help me. Some patients are running out of their prescriptions and no one to refill them.
    I guess what I'm getting at, going to a doctor is stressful by itself. They need to start treating people for post traumatic doctor syndrome! :)
  7. Jorihe84
    Jorihe84 Road Train Member
    2,763
    1,333
    Sep 1, 2010
    North Florida
    I had a sleep study done in may of last year.. I passed it but I'm wondering if they'll try and flag me again in February.
  8. Mommas_money_maker
    Mommas_money_maker Road Train Member
    1,122
    765
    Oct 2, 2011
    North Carolina
    Im with Condo on this one. I have a large neck and a high BMI with type 2 diabetes, this doesnt mean I have sleep apnea. Have them check your a1c level. It should be a simple poke of your finger and about 2 drops of blood taken. They get a reading of your blood sugar for the past 3 months and then determine diabetes. 6 and under, should be good as gold. 7 and over, you probably have it. Mine was a 12 and I dont take insulin. Mine is now taken care of by pills and mainly diet. Eat healthy and keep the weight down and drink lots of water and you will solve a lot of health issues.
  9. Allan M
    Allan M Medium Load Member
    453
    283
    Apr 20, 2009
    Go apply at a different company.
    I've been on CPAP for 14 years.
    I see my Pulmonologist once a year with a download from my machine in hand.
    He gives me a letter to take to my DOT Medical.
    I receive a one year card.
    I don't understand why you guys even waste your time with those mickey mouse big box carriers anyways.
    123456, Shaggy76 and Joetro Thank this.
  10. MicaBay
    MicaBay Medium Load Member
    563
    186
    Nov 23, 2011
    Idaho, North
    Cause most mom and pop operations don't want to train.
  11. Shaggy76
    831
    307
    Feb 22, 2012
    Orlando, FL
    From my unserstanding, if you have it, you have to show prrof of compliance every year. If you don't, here is where it gets really aggravating. You can have the test done, but it has to be 90 days or less prior to your physical. If older than 90 days, you have to be tested. So in a nutshell, if you get tested and it is said that you don't have it and are given a two year card, expect to pay for another test in two years.
    Part of the problem I had with Link is I had to pay for this test, even if my doctor was totally against it. It would cost me $740 since that is my deductible. Why dod I have to have a test that I am told is required by the doctor because the doctor said it is required by the DOT? If it is required for me to work for the company as part of the approval process, than the company should pay the deductible. They don't andthey won't. Most drivers I have talked to at some of these companies that once they are told they have it, companies will black ball them for you are now a liability to drive that truck. Get into an accident and it comes out. Flip of that coin, if you are not treated for it and the DOT says you could have it based on BMI, the company still gets fried.
    So I did what a lot of other drivers are doing. I just said forget it and left the industry to go back to what I enjoy doing anyway. I turned my back on the industry the same way it turned its back on me. I walked away with the negative feelings of the company and will continue to have these negative feelings. The undustry has changed and the people are leaving it faster than they can get people in it. It is sad, but trucking ruins lives anymore. Some are lucky, but most will not be...
