The "Spread" of Ignorance
Discussion in 'Ask An Owner Operator' started by 7mouths2feed, Mar 21, 2010.
  1. 7mouths2feed
    7mouths2feed "Family Man"
    1,186
    464
    Nov 29, 2007
    Jacksonville, AR
    Hi All, It seems I will be buying a spread axle hopper and freely admit to my ignorance :biggrin_25521:of spread axle "Do's and Don'ts" :biggrin_2551:. Rather than learn the hard way:biggrin_2555: :biggrin_2553:I am calling on my trusted fellow truckers to educate me.
    Also if anyone has done or can point me in a direction for more info reguarding converting one of the axles to a lift style I would be greatful for the info.:yes2557:
    I offer my thanks to all in advance.
    kickin chicken Thanks this.
  3. RW.
    RW. Heavy Load Member
    715
    995
    Jan 18, 2009
    west central IL
    This isn't quite what I thought the thread was going to be after I read the title, I thought there was going to be a pretty good rant going! :biggrin_25519::biggrin_25516:
    Make wide turns when possible rather than sharp ones. An electric dump valve on one axle can be helpful. The ride is much better than a regular tandem. I haven't been able to get recaps to last on our drop, after a while the tread starts to peel away from the sidewall.
    That's about all I know for sure, not too much. :biggrin_25513:
    7mouths2feed Thanks this.
  4. Jfaulk99
    Jfaulk99 Road Train Member
    2,914
    1,652
    May 16, 2009
    Couch
    Like RW said limit sharp turns as much as possible, A dump valve on the rear axle will make your trailer 5' shorter at the flip of a switch (assuming it's a 10' spread). You can make either axle a lift (hendrickson suspensions are easier and cheaper than neway to lift). What brand of trailer? Timpte and Cornhusker are die hard Neway where Wilson uses Hendrickson.
    Just guessing but I say you'll love it. Ride is WAY better, with a dump valve maneuverability is better and you'll never have to pay to scale your truck again. Caps work fine as long as you buy the caps for a spread (closed rounded shoulders) We run caps on almost all our spread axle flats with making stop and go deliveries in town with no issues.
  5. dino6960
    dino6960 YOUDAMAN
    1,347
    4,583
    Jun 25, 2009
    florida
    also 5 mouths im not sure of this but when i ran flatbed you can carry 40000 on the spreds vs a tandum,as far as the dump valve i would truly look into makeing that happen ,it would be worth the investment so you can save on tires,,hope its going better than it was when i talked to you last,,give me a call when you get a chance there driver,,,hope all is well with the family and your loads are closer together the dino
  6. 7mouths2feed
    1,186
    464
    Nov 29, 2007
    Jacksonville, AR
    Correct me if I am wrong but I believe what you all are saying is that I just need an air dump valve for one of the axles? And that a lift conversion would be a completely different dinosaur?
  7. Jfaulk99
    2,914
    1,652
    May 16, 2009
    Couch
    If it's Neway suspension here are a couple links to the lift kit for them.
    It's shown at the bottom of this brochure.
    Installation instructions.
    I got a price for around $800 for the kit. Not sure if it included the valves.
    If it's Hendrickson suspension.
    Under Beam Lift
    Parts List
    I've bought one of these. Simple to install since it's weld on unlike the Neway that requires you remove the pivot pin. I paid about $500 for this kit without the "air kit" which Hendrickson wanted another $500. I just used electric solenoid valves.
  8. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,540
    Jul 30, 2009
    Mapleton Depot,PA
    being able to dump the air for the rear axle will make it much easier to manuever, but some manufacturers will tell you that this will void their warranties because you could overload the front axle.
  9. Winchester Magnum
    Winchester Magnum Road Train Member
    1,492
    1,647
    Jan 4, 2009
    Alaska highway
    The cab contolled quick dumps are illegal, however it's just yet another stupid law that gets broke along with the other 10,000 laws. That said, they are sweet and you should get the quick dumps.......(grin)
  10. 7mouths2feed
    1,186
    464
    Nov 29, 2007
    Jacksonville, AR
    More info On the quik-dumps please:yes2557:
  11. Winchester Magnum
    1,492
    1,647
    Jan 4, 2009
    Alaska highway
    In short, they are electricaly contoled solinoids, one on each axle, and when activated they dump all of the air out of the 2 bags on the axle you are dumping. You have 2 cab switches (you'll need to fabricate the design and wiring yourself), each cab switch dumps one axle, and they dump the air completely in about 3 seconds flat (hence "quick" dump). These solinoids are set so they will only dump when electricaly charged, therefore, the bags will stay inflated as a default, like when you're unhooked from the trailer. Older trailers will have a 6 prong recepticle plug from the factory, newer ones I'm not sure. If equiped with the 6 prong plug on the trailer, you can buy the male end at any auto parts store for about $6. They are esentialy a couplable wire harness for a pickup and boat trailer.
    Super short version = run wires from cab (via switches) to energize both solinoid valves so to dump air as desired. When they are de-energized, the solinoids will not dump, and your bags stay inflated.
    If I get some time sometime soon, I'll take pics of my setup and post, as an illistration would be easier to understand.
