The ultimate GPS! (almost)?
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by YETI1, Aug 10, 2011.
  1. YETI1
    YETI1 Light Load Member
    182
    40
    Jan 1, 2008
    kansas
    The iGPS the largest screen, the most useable piece of equipment ever.Well I think its cool:biggrin_2554: using an external gps reciever to the ipad,ram mount. The only limits are the truck specific software at this time. Acurate within a foot of the truck,lol
  3. Aztech
    Aztech Light Load Member
    62
    22
    Feb 17, 2010
    Townsend, DE
    I was going to use an iPad2 with copilot as a gps, but verizon told me the aGps, as well as external receivers only use cell tower signals and require data.
    I tried the 10 inch Flytouch 3 android tablet, but that tablet's gps is locked in china, and doesnt allow the user to make an android market account, so that was unusable.
    I use a laptop (which i keep closed) with a 7 inch touch screen and copilot, which acts as a 7 inch gps. Can use a 10 inch screen as well, but i find 10 inches a bit big for the dash board.
    Im in the process of upgrading to a mini tower pc with a lot of USB ports. That will allow multiple touch screens to be running as well as dash cams and mirror cams. You could control copilot gps from 1 touch screen, and watch a blind-side cam from another, while recording all cams onto the disc drive. You also have google maps and stuff while connected to a wifi. Sure iPad has google maps too, but you have to switch apps to use it. iPad is extremely limited on what you can do. Windows will let you do almost anything.
  4. YETI1
    182
    40
    Jan 1, 2008
    kansas
    no cell towers?! mine is a wifi.. only no data!
  5. zebcohobo
    zebcohobo Vincent Van Gopher
    1,479
    1,223
    Jul 19, 2010
    Redbank,SC
    The most useable piece of equipment is still the 'ol spiral bound truckers atlas. If used correctly it won't send you under a low bridge or into a residental neighborhood.:biggrin_2559: No truck specific software needed.
  6. sazook
    sazook Road Train Member
    1,471
    548
    Jun 1, 2009
    Springfield, MO
    That is incorrect. AGPS stands for Assisted GPS. It uses regular GPS and is assisted by the cell phone towers.
    http://en.wikipedia.org/wiki/Assisted_GPS
    I have an AT&T iPad that I no longer have a data plan on, and the GPS works flawlessly.
  7. YETI1
    182
    40
    Jan 1, 2008
    kansas
    Exactly ! :biggrin_2558:that's why I added the external gps receiver . I think it has stronger reception than the iPads ...mine was a wifi only unit therefore needing it.
