Thermo King APU electrical problem
Discussion in 'Trucks [ Eighteen Wheelers ]' started by abenaki, Mar 18, 2014.
  1. abenaki
    abenaki Bobtail Member
    29
    4
    Jan 22, 2014
    I have a thermo king apu and when I go to use it, the F8 fuse blows almost instantly. Any ideas would be appreciated. Thanks
    I should have noted that it does not have DPF exhaust.
  3. bjytech
    bjytech Light Load Member
    244
    221
    Nov 9, 2013
    If I remember right fuse F8 is for the engine switch on the apu, so if it's blowing right away the power wire going to the switch is shorting out somewhere.
    abenaki Thanks this.
  4. abenaki
    29
    4
    Jan 22, 2014
    Thanks for the suggestion. I will open it up and try to track it down from the switch. Thanks again.
