Thermo king apu not running need help?
Discussion in 'Ask An Owner Operator' started by tommyelamey, Feb 3, 2013.
  1. tommyelamey
    tommyelamey Bobtail Member
    Have a thermo king not running. It rolls over but obviously not getting fuel. I have changed the fuel filter and the little filter in the back of the engine with no change. I am starting to wonder if this is a fuel pump issue. Maybe something simple maybe not any help out here??
  3. MNdriver
    MNdriver Road Train Member
    7,985
    4,372
    Feb 24, 2012
    if you changed the filters, like I did last fall.
    I cracked one of the fuel lines for the injectors at the pump. It let the air bubbles out and helped prime the pump.
    JTRUK and CondoCruiser Thank this.
  4. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,540
    Jul 30, 2009
    Mapleton Depot,PA
    Check the fittings on the pump and the plastic lines to them. I have had the fittings work loose from the compression fittings, and had one plastic line rub thru against another one. None of that is visible unless you remove the cover.
    You may want to make sure the off switch under the cover was not tripped and be sure the breaker button is in on the control box in your side luggage compartment too.
  5. skateboardman
    skateboardman Road Train Member
    6,232
    5,706
    Jan 14, 2012
    flatbed heaven
    my apu has same engine as thermo king, i have an electric fuel pump in between the two filters. see it it has power. check all the fuses.
  6. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    It hasn't been mentioned so I must ask, "Did you bleed the system"? If you don't give it a means for the air to escape it will dead pump.
    Do you have any alarm codes stored?
  7. MNdriver
    7,985
    4,372
    Feb 24, 2012
    uh, yeah it was......
  8. Larryparker
    Larryparker Medium Load Member
    334
    215
    Jan 23, 2010
    Boynton beach, FL
    What is the fuel level in the tank you are drawing from, if it is less than a quater, the apu may not be pulling fuel from the tank.
    Good Luck,
    Larry
    JTRUK and Hardlyevr Thank this.
  9. brysol01
    brysol01 Medium Load Member
    312
    445
    Nov 2, 2009
    mine has the same motor, fuel pump wires broke from vibration just inside the pump, found them by wiggleing the wires, installed new lift pump, got it squirting , been great ever since
    JTRUK Thanks this.
  10. CondoCruiser
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    uh, by the OP! :)
  11. jason6541
    jason6541 Road Train Member
    2,425
    5,366
    Mar 5, 2012
    Omaha, NE
    Just before engine starts to turn over after the buzzing noise quits from preheat mode. You should here the electric lift pump kick on.
    JTRUK Thanks this.
