Thing about switching trailers
Discussion in 'Ask An Owner Operator' started by freight-time, Dec 22, 2015.
  1. freight-time
    freight-time Light Load Member
    255
    104
    Nov 5, 2015
    I'm thinking about ditching my dry van,and getting a refrigerated trailer,or flat bed .I'm a little torn.
  3. mp4694330
    mp4694330 Road Train Member
    1,529
    1,459
    Aug 30, 2010
    Chicagoland
    Seems like You do dry van spot loadboard freight (same like me).I would be very careful with buying new(er) equipment now.Get in touch with somebody who does that type of work in Your region and ask questions.Also do You have reefer and open deck experience?
  4. freight-time
    255
    104
    Nov 5, 2015
    Thanks for your response. I have had just a little exp with reefer ,and flatbed.
  5. 201
    201 Road Train Member
    12,441
    25,443
    Apr 16, 2014
    high plains colorado
    Hi freight-time, no question, flat bed. While they may be a little harder to load, I wouldn't pull a reefer again if my life depended on it. Flatbed has so many advantages over a box, people generally need what you are bringing, no pallets or warehouses to deal with, generally, not ball-buster loads, like with a reefer ( which are heavy empty to begin with) and just a lower frustration factor. ( not to say, there aren't ugly flatbed loads, but not too often) If you ever have a question how to load something, do what I did, just look at how the other drivers do it. If you go with a reefer, consider yourself warned. Good luck.
    spyder7723 Thanks this.
  6. freight-time
    255
    104
    Nov 5, 2015
    Thanks for that info.Have ab awesome day.
    201 Thanks this.
  7. Oscar the KW
    Oscar the KW Going Tarpless
    12,246
    28,116
    May 19, 2011
    Why do you want to switch?
  8. DUNE-T
    DUNE-T Road Train Member
    6,978
    16,934
    May 10, 2015
    Detroit, MI
    I was also thinking about switching and getting a Conestoga. Would it be a good idea to get that or just regular flatbed will do?
  9. Chewy352
    Chewy352 Road Train Member
    1,797
    11,619
    Dec 17, 2013
    Enid, OK
    I would love a Conestoga but it will limit what you can haul. If you had dedicated freight I could see it being benificial but if you're hauling whatever you can find it will limit you.
    DUNE-T Thanks this.
  10. spyder7723
    spyder7723 Road Train Member
    15,471
    25,076
    Mar 31, 2013
    sarasota, fl
    What chewy said. A conestaga would be awesome on certain dedicated accounts. But for general stuff you find off the load boards, not a good idea. Most shippers don't want to fool with them cause they think they will be difficult to load. I bet if you put a hundred shippers in a room only five of them will know a conestaga is not a curtain side van. or they think it's a covered wagon so only five foot tall.
    DUNE-T Thanks this.
  11. Chewy352
    1,797
    11,619
    Dec 17, 2013
    Enid, OK
    I think, and I may be wrong, a step would give you the biggest range of loads.
    DUNE-T and freight-time Thank this.
