Things I wish my trainer had taught me
Discussion in 'Questions From New Drivers' started by Odin's Rabid Dog, May 20, 2018.
  1. Odin's Rabid Dog
    Odin's Rabid Dog Heavy Load Member
    704
    1,717
    May 6, 2018
    NW MT
    I'm going to put this here. This is not comprehensive, just a few for starters.
    New drivers, here are a few things you might want to consider:
    1- preplan analysis- enough hours to get that load delivered on time? (Remember, 70, 11, and 14 clocks will bite you if you're not meticulous). Consider that heavy loads or hilly terrain will slow you down. Weather might, too, and don't forget time zones!
    2- route planning- and, where you gonna park (and fuel) that thing? (Have a backup plan, too.) Where will you take breaks? Use atlas, Google maps, trucking Apps such as RoadBreakers, TruckerPath, etc.
    3- conductive grease for electrical pigtail, weekly. Reduces corrosion. Can be bought at most auto parts stores.
    4- keep the 5th wheel lubed
    ..... A- skid plate grease- 10 oz. crushable water bottles filled w/ bulk grease (your terminal shop may or may not fill them for you) work well
    ..... B- mechanisms on underside- PB Blaster, WD40, etc, keeps the 5th wheel latch working smoothly, more important in winter due to road salt (regional)
    5- keep plain clay kitty litter, a couple of plastic gallon jugs in case of icy parking lot or drop yard (Regional)
    6- carry crankcase oil, washer fluid, coolant, power steering fluid, spare wiper blades, spare bulbs (low beam & turn signal at least) and glad hand seals
    7- carry tire chains (and bungies). Know how to throw them. (Regional)
    8- small clipboard with small notepad velcro'd or hung on dash. Write route, hiway numbers, street names, miles to each turn
    9- shower squeegee for mirrors (not really necessary, but sometimes nice to have, especially first thing in the morning
    10- ALWAYS visually inspect trailer tandem slide (if so equipped) to verify all lock pins are fully engaged. Pretrip, post trip, after sliding tandems, after using the restroom.
    11- Always "take the long way back", meaning, after taking a rest room break, fueling, lunch, whatever, walk the long way around the truck, kicking tires, checking mud flaps, verifying no one pulled your 5th wheel or tandem lock levers, look underneath for drips/leaks, check trailer doors or load straps, tarp/bungies, that kind of stuff. Make it a habit.
    12- if using swing door trailer, keep a couple of bungies handy, 12" to 16" to hold the doors when open. The chains on a lot of trailers to hold the doors open are unreliable.
    13- when dropping a loaded trailer, don't stow the crank handle, but rather , let it hang free, or the weight could jam the handle in the stow bracket making it really hard for the next guy to crank it .
  3. Dino soar
    Dino soar Road Train Member
    4,791
    26,878
    Dec 8, 2017
    1) clean truck for the next guy if. company
    2) Toilet paper- you never know
    3) small tool set, cable ties, rags, and a. flashlight
    4) Windex and paper towels
    5) airline to blow dirt out and inflate tires
    CDLman63, 417bigK, MBAngel and 8 others Thank this.
  4. driverdriver
    driverdriver Road Train Member
    4,254
    5,283
    May 30, 2011
    Good post.
    Good post.
  5. Akwilson
    Akwilson Bobtail Member
    13
    27
    May 6, 2018
    I just use the fuel from emptying the water separator to keep my 5th wheel latch lubricated. This may surprise you, but WD-40 is not a good lubricant, but it is a good solvent to free stuck parts, so it's handy to keep around.
  6. Kyle G.
    Kyle G. Road Train Member
    3,853
    20,232
    Jan 23, 2016
    Eastern Iowa
    I saw a guy once who wrote his route down on the door window with a dry-erase marker.
  7. Ridgeline
    22,402
    116,509
    Trainers are not trainers, they are mentors at best and just make sure you won't get in an accident in your first few weeks.
    Rollr4872 and Odin's Rabid Dog Thank this.
  8. Trucking in Tennessee
    Trucking in Tennessee Road Train Member
    3,740
    5,740
    Mar 19, 2018
    Nashville
    I keep a roll of duct tape and hand cleaner. For fueling you can get a pair of grey/yellow gloves at harbor freight for $2. They are rubber on the palm and work great . A hammer for tires and pins that stick, along with WD40 for them. Flashlight for checking the 5th wheel pin, etc. A notebook for writing down whatever as a reminder. A big clip to hold bill of ladings. A crate that holds a gallon of oil, antifreeze, window washer fluid and rags or blue towels.
  9. Wooly Rhino
    Wooly Rhino Road Train Member
    3,367
    5,648
    Jul 6, 2008
    Liberty, Missouri
    Don't forget when you are doing a walk around that if the Truck or trailer has the words on it like Swift, K and B, Trans Am or Werner that you probably don't want to get into those trucks.
    Kyle G., x1Heavy, Lav-25 and 3 others Thank this.
  10. Aces-N-Eights
    Aces-N-Eights Light Load Member
    135
    200
    Feb 21, 2018
    Mobile, AL
    Excellent lists of mechanical / work related items. I'd like to throw my $.02 in about driver fitness.
    It can all start with healthier food / snacks - While some truck stops are getting better about carrying healthier items, make sure you are not just getting full but full on foods that support your body. Take it from a guy that was almost 400lbs two summers ago and is now right at 185lbs. Two years a d one gastric surgery later, here's some stuff I've learned along the way about eating healthier on the road. I always pack:
    1) VEGETABLES & FRUITS - canned lasts, fresh if you are near grocers frequently - not near as good as fresh but still I vital source of vitamins, minerals, and antioxidants
    2) SOURCES OF PROTEIN - tuna fish, peanut butter, dinner recipes with black / red / kidney beans, nuts like almonds / pecans, high protein items will will you up faster too
    3) SNACKS - rice cakes, string cheeses, baked chips or veggie straws, granola, almonds or pistachios
    4) HYDRATION - a bottle of water with a no/low cal flavor insert can kill a food craving and is GREAT for your body.
    Now for the big ones....
    5) EXERCISE - I know, sounds horrible... but exercise is vital for your cardiovascular system. Just a 10 min brisk walk daily will not only improve circulation, but it will boost your endorphin levels (make you feel good)
    6) STRETCHING - along the same lines as exercise, it's very important to stretch you muscles. Adjusting your sitting position every 30 mins, good posture while driving, and having your seat properly adjusted can help reduce soreness and fatigue.
    By no means a complete list, it you see what I'm getting at. Your most valuable resource is YOU!! All the extra parts in the world won't fix you. Remember to PM the driver too!! :)
    misterG, spindrift, 417bigK and 6 others Thank this.
  11. Linte_Loco
    Linte_Loco Road Train Member
    1,618
    6,485
    Apr 24, 2011
    LA (lower Alabama)
    “If that’s the worst thing that happens today, then it’s a good day”
    Don`t sweat the small stuff
    nax, Kyle G., Rollr4872 and 3 others Thank this.
