Things on a truck a cop would look at for a random inspection?
Discussion in 'Questions From New Drivers' started by marvelousmack, Aug 1, 2021.
  1. marvelousmack
    marvelousmack Light Load Member
    142
    65
    Mar 5, 2021
    Or if you get stopped at a weigh station. I started a new job and the truck works ok but it is kind of a piece of junk. Rusty. The handles to grab onto to get into the back of the truck are totally dented in. Is that something I can be faulted for? It's a box truck by the way. Thanks
  3. CrappieJunkie
    CrappieJunkie Wishin' I was fishin'
    3,996
    19,137
    Mar 9, 2014
    In a van down by the River.
    You had to pass a pre-trip to get your cdl, right? Everything you had to show in pretrip, is anything a cop could check. In my one level 1, the cop checked everything.
  4. marvelousmack
    142
    65
    Mar 5, 2021
    Yeah but it's been so long I'll have to brush up. Thanks
    CrappieJunkie Thanks this.
  5. CrappieJunkie
    3,996
    19,137
    Mar 9, 2014
    No problem. Most only check lights, brakes, tires, the major stuff. I doubt they check fluid levels and such, but make sure you have your triangles or flares, extinguisher and fuses.
    bentstrider83 Thanks this.
  6. Opus
    128,337
    My experience is, they'll find what they want to find.
    I'm sitting in a truckstop now, and I could put any one of these guys out of service.
    It is so totally subjective.
  7. Moose1958
    Moose1958 Road Train Member
    15,257
    33,813
    Dec 17, 2010
    Williesburg, Virignia
    Link
    Click on the chart it should be large enough to read! This is the general stuff a by-the-book inspection covers!
  8. Moon_beam
    Moon_beam Heavy Load Member
    885
    1,285
    Aug 29, 2012
    Is the registration legible? Do you have instructions for the electronic logging device, (ELD)?
    bzinger and CrappieJunkie Thank this.
  9. buddyd157
    buddyd157 Road Train Member
    13,582
    34,896
    May 25, 2017
    under a shade tree
    if you are starting a new job, with a new CDL, and if the truck looks as bad as you are saying.....what do you realistically think they will look for..???
    a DOT cop can find anything wrong at any time.
    if you value that CDL you just got?
    maybe look for jobs that have better equipment?
    already sounds to me like that company doesn't really care one way or another about YOUR CDL.
    make sure you write up everything during your pre-trip, but remember, once you drive it out the yard, you own it.
    alds and CrappieJunkie Thank this.
  10. Dockbumper
    Dockbumper Road Train Member
    3,778
    9,861
    Apr 29, 2020
    I would add: properly inflated tires, they have infrared sensors that will light up a hot underinflated tire. Audible air leaks. And the most important thing you should check is your ATTITUDE! If the inspector is treated with respect, 99% of the time it will go both ways. Wanna' pull your billy badazz routine with the inspector?? You are on your own.
  11. CrappieJunkie
    3,996
    19,137
    Mar 9, 2014
    Keeping the attitude in check is the most important thing. If you do as they say you will be fine, as long as the truck is in good working order. Despite what some believe, the DOT is not there to jam you up, they are just making sure you are operating safely.
    Bean Jr., buddyd157 and Dockbumper Thank this.
