Thinking bout going pneumatic
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by Crazydump, Oct 24, 2018.
  1. Crazydump
    Crazydump Bobtail Member
    10
    5
    Oct 21, 2018
    Raymondville mo
    howdy crew I’m considering going pneumatic with my company and I’ve been doing end dump never messed with a pneumatic. So my question is what am I getting into dos don’ts Ect. Any help or advice would be grateful
    motocross25 Thanks this.
  3. motocross25
    motocross25 Road Train Member
    3,877
    11,892
    Sep 23, 2010
    Overland Park, KS
    I know nothing of it either. The only thing I have heard before, is beat the side of the tank with a rubber hammer, not a metal one.
    RockinChair and bottomdumpin Thank this.
  4. REO6205
    REO6205 Road Train Member
    13,168
    60,499
    Feb 15, 2014
    California.
    What kind of products are you going to haul? There's a world of differnce between cement and something like plastic pellets.
    Suspect Zero Thanks this.
  5. Suspect Zero
    Suspect Zero Road Train Member
    2,529
    9,730
    Oct 10, 2016
    Brookfield, IL
    I would have to second what @REO6205 asked first, it will make a difference.
    I'm assuming they are going to train you with a pneumatic driver and not just give you 5 minutes of verbal pointers and send you on your way.
    Best I can give you right now is take lots of notes. Write down everything. I switched to pneumatic about 5 months ago and the first couple weeks of my training I was worried I wouldn't pick up (we deal with a decent amount of different products and each has it's own things) all the little things that are product specific.
    The first few months after getting kicked out of the nest and on my own I was constantly looking back thru my notebook to make sure of things before doing them.
    After a time I think it all becomes repetition and you start to figure out the small things the trailers/blower are telling you as you load/unload but I still refer to my notebook.
    bottomdumpin Thanks this.
  6. Air Cooled
    Air Cooled Road Train Member
    1,315
    1,094
    Jul 17, 2011
    Baltimore
    If your pulling dumps and it’s within your company, it’ll be most likely cement, slag, and flyash. They may throw some sand your way when it’s slow. Cement products are no big deal. Lots of steps to learn and you’ve got to watch your work but it’s a good switch. I did different kinds of dump configurations within my company but I always liked pneumatic the most.
  7. Crazydump
    10
    5
    Oct 21, 2018
    Raymondville mo
    Thanks guys. I know concrete I think sand not real sure it’s the company’s first year with it so I’m not sure I know there’s more work but I’m a lil nervous bout it cause I know there’s more to it then just hooking a hose and releasing a lever
  8. blade
    blade Heavy Load Member
    881
    647
    Jan 30, 2009
    Some where, Mo
    My advice is make sure they show you how to unplug a line!! Listen for the different sounds the tank will make. Carry extra gaskets sucks to spring a leak. Practice controlling your pressures!! A mallet is okay but I like deadblow better but good cold weather and rain gear is a must!! I really miss pulling a tank good luck
    RockinChair Thanks this.
  9. REO6205
    13,168
    60,499
    Feb 15, 2014
    California.
    Ir's not real hard to learn but it requires a certain amount of focus. You do all the unloading yourself and a lot of times there might not be anybody around to help you if things go wrong.
    If you're hauling cement and then hauling something else afterward...lime, ammonium nitrate, salt, cinders, or a number of other things make sure your trailer is cleaned out before you load cement again.
    If you contaminate a trailer of cement it can get costly. If you contaminate an entire storage silo of cement it can ruin you.
    Zeviander Thanks this.
  10. Bill51
    Bill51 Road Train Member
    1,185
    2,982
    Jul 27, 2015
    There's videos on utube. I hauled stuff that was baby powder in consistency. Like mentioned above, no one around where I loaded and unloaded. After plugging a hose or two, and the discharge line on the pup, I learned to open that product valve slowly with plenty of air to the product line and give that stuff a chance to get moving.
  11. rbrtwbstr
    rbrtwbstr Road Train Member
    3,399
    7,925
    Jul 11, 2012
    in the bush somewhere
    There's a whole thread on here about pneumatic tankers.
