This doesn’t look right
Discussion in 'Questions From New Drivers' started by Penumbra, Nov 7, 2019.
  1. Penumbra
    Penumbra Medium Load Member
    305
    528
    Jul 29, 2019
    The company isn’t concerned about this...but it definitely feels like more than one inch of play.
    road rescue said DONT worry about it...
  3. buddyd157
    buddyd157 Road Train Member
    13,576
    34,885
    May 25, 2017
    under a shade tree
    if a mechanic said it's ok, then it's ok.
  4. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    Can tell exactly nothing with your video, you have to watch the pitman arm, not go by how far you can turn it.
  5. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,137
    Mar 5, 2016
    White County, Arkansas
    This is going to be a long year.
    Don't they train the free wheel play limits anymore at the steering wheel inside the cab?
  6. skellr
    skellr Road Train Member
    8,737
    12,187
    Jul 17, 2011
    The Village, Portmeirion
    Sounds about right...
    Go to a truck dealer and try it on any NEW truck for a surprise
  7. Ffx95
    Ffx95 Road Train Member
    1,368
    2,628
    May 18, 2017
    Am I missing something here? I thought you tested play with the engine off so you’re not getting fooled by the power steering assist. Someone reply maybe I’ve been doing it wrong this whole time.
  8. x1Heavy
    34,017
    42,137
    Mar 5, 2016
    Sit in cab engine off, try to move steering wheel. It should only do a little bit of movement. Not very much at all.
    Nothing making too much noises while doing it either. Drive off.
    truckdriver31 Thanks this.
  9. starmac
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    Even with the engine off, you can be moving the pitman arm, even more so if you are using the steering wheel.
    Move the steering shaft back and forth while watching the pitman arm, the free play is only how much it moves before the pitman arm starts to move even a minute amount. If you can detect any movement at all on the pitman arm, you are past the point of freeplay.
  10. REO6205
    REO6205 Road Train Member
    13,171
    60,501
    Feb 15, 2014
    California.
    Did a DOT inspector find that or did you call out road service yourself?
  11. Penumbra
    305
    528
    Jul 29, 2019
    Wow I learned a lot from this thread!
    Yes that’s how they taught us to check the play! No truck at school ever did that! But then again those trucks were garbage!
    thanks for the lesson guys you rock!
    truckdriver31, FlaSwampRat and x1Heavy Thank this.
