this is a serious ??? no sarcasm please
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by realsupatrucka, May 7, 2014.
  1. realsupatrucka
    realsupatrucka Road Train Member
    2,072
    513
    Sep 25, 2013
    houston tx
    Tankers on ice and snow...how does it handle...if u on the brakes will the surge hit and make it slide...do you drive on ice or do you pull over...im speaking loaded tanks
  3. bad-luck
    bad-luck Road Train Member
    3,296
    6,060
    Nov 16, 2013
    Baltimore, Maryland
    On ice it doesn't matter what your driving.... get off the road no load is worth the risk. As for snow it depends if your tank has baffles or not. No baffles would surge. Baffles would have minimal surge but the closer you are to the tank being full would reduce surge
    Solo_Seat and Big Duker Thank this.
  4. ramblingman
    ramblingman Road Train Member
    1,152
    1,115
    Jan 12, 2014
    I'm hoping this was Sarcasm. Do you just shut down till spring?
    ethos Thanks this.
  5. realsupatrucka
    2,072
    513
    Sep 25, 2013
    houston tx
    We only have smooth bore tanks...none of them have baffles...we are pretty much always full...5500 to 6000 gallons most of our tanks hold 7000 gallons. .but u know it depends on the weight of the liquid
  6. Solo_Seat
    Solo_Seat Medium Load Member
    416
    215
    Apr 8, 2013
    Jacksonville, FL
    I would say that was sound advice. On ice, you shut down until the conditions get better...over night or a day usually.
    Big Duker Thanks this.
  7. walstib
    walstib Darkstar
    Your Handling of vehicle more than road conditions determines surge. If anything less surge on ice and snow from less traction, maybe immeasurable, but there. All vehicles are driven based on conditions, some vehicles, like tankers, have extra concerns which you at least are aware of. It'll take a bite or two out of your seat before you get it just right just side with caution and you'll figure it out. Lastly, when in doubt, sit it out.
  8. Dr_Fandango44
    Dr_Fandango44 Road Train Member
    1,053
    746
    Aug 27, 2012
    Austin, TX
    Yes you can't control what it will do on ice. It's going to be even worse if you're empty.
    I vividly remember this young lad in a Chevy actually go under my trailer as I was crawling along on a slick frwy in MI a few years ago. and totaled his car. No harm done to me but there was nothing I could do. He was driving too fast.
    And as for chains, if I had them. They would stay where they are as decoration only.
    In my rookie years an old timer once told me...."chains?" "If you need chains lad, you shouldn't be driving"
    very wise words and in my estimation ice is even worse.
    Good luck
    OPUS 7 and Crossroads Thank this.
  9. Derailed
    Derailed Road Train Member
    2,383
    2,657
    Dec 10, 2008
    Upstate NY
    I know that seems to be one of the favorite answers on here but in this neck of the woods you wouldnt have a job at a lot of places that run local/regional. Slow and steady always worked well for me. As far as the surge having an effect on ice I would say very little. Taking different routes on the bad days such as the long way around on the interstate vs. over the hills and through the woods also. If I remember correctly the OP just started pulling tankers. You will get used to them quickly if your not already and its good your getting the time in over the fair weather season. By the time winter comes around you will be in good shape.
    realsupatrucka and cowboy_tech Thank this.
  10. realsupatrucka
    2,072
    513
    Sep 25, 2013
    houston tx
    I wish I could do that...but I wouldn't make any money like that...it snowed all the time last winter
  11. realsupatrucka
    2,072
    513
    Sep 25, 2013
    houston tx
    So make me aware. ..im driving on ice in flatbed...but tanks are a whole different animal
