This is what happens when you don't pretrip the truck!
Discussion in 'Experienced Truckers' Advice' started by truckerdave1970, Sep 3, 2011.
  1. truckerdave1970
    truckerdave1970 On Probation
    2,987
    3,289
    Dec 15, 2008
    Rochester, NY
    I wasn't going to post this at first, but what the hell? Maybe someone will read this and it helps them to avoid the same mistake!
    THIS WAS COMPLETELY MY FAULT!!!
    I make no excuses.
    I failed to properly pretrip the truck. It was this past winter, extremly cold. My fellow driver made it to work a few minutes before and did me a favor and hooked up my trailer to my tractor. I arrived after he left the yard, did a VERY abbreviated inspection, attempted to do a "tug test", to ensure that the fifth wheel was locked as I couldnt see under the tractor as it was dark and my dumb arse didn't bring a flashlight to work. Well the yard was covered in snow and ice so I wasn't able to really get a good tug. I moved onto the driveway that was clearer and "tugged" again, now I was 90% satisfied that all was good.
    I left the yard, traveled about 1/4 mile, stopped at the red light, smoothly accelerated while expertly executing a left turn once the light turned green, and as soon as the trailer straightened out I began to upshift. Somewhere around 5th or 6th gear, I felt and heard the absolutely worst thing a driver can hear!!!
    :biggrin_2551::biggrin_2551::biggrin_2551:
    MY TRAILER DISCONNECTING FROM MY TRACTOR WHILE I AM DRIVING!!!
    I don't know if it is clear in the pics, but my fifth wheel WAS STILL CLOSED and the handle for it is clearly in the LOCKED position! My slightly intelligent, somewhat experienced guess is that when my coworker backed under the trailer, it was too high for the fifth wheel to properly lock in the kingpin. If I would have had a flashlight, I probably would seen a gap between the fifth wheel and the kingpin mounting plate on the trailer!!!
    Thankfully, it was still early in the morning and traffic was light. No one was injured (except my pride!!!) The equipment was not damaged, not even the air lines and pigtail surprisingly. I was able (barely, freakin' heavy arse trailer) to crank the trailer back up and reconnect it properly before any LEO could show up and add insult to injury.
    Drivers, this is why we have to do a proper pretrip. I was extremly lucky, it could have been really bad.
    So without further ado, here are the pics: I apologize for not taking more, I was pretty rattled that morning.
    venne, SheepDog, tinytim and 19 others Thank this.
  3. johnday
    johnday Road Train Member
    Whoa there!! Never had that happen, but I'll bet it tightened up your shorts a bit. That's one of my worst fears. I usually drop my trailer when I get back to the yard, and just back under the trailer the day shift guy likes, to keep someone else from grabbing it. I DO NOT back under all the way, and DO NOT hook up the air or pigtail. I leave it to where it's obvious it isn't hooked.
    He does the same for me if I'm not there. But I made it clear, please don't hook it, I'll do it myself. That way I won't assume everything is fine, and just do a quick PTI like you did. No, I'm not trying to add insult to injury, you're VERY lucky, and I just know you won't do that again!!:biggrin_25525:
  4. Allow Me.
    10,676
    12,237
    May 28, 2009
    Rancho Mirage, Ca.
    Want it done right ????? Do it yourself......
  5. quickway
    quickway Light Load Member
    183
    87
    Feb 1, 2011
    louisville ky
    I'm sure with all of the instant adrenaline you got when it disconnected and fell into the street you had NO problem dollyin that baby up.
    SheepDog and truckerdave1970 Thank this.
  6. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,540
    Jul 30, 2009
    Mapleton Depot,PA
    I have had similar experience, twice, but for a slightly different reason. Both times I did a tug with the trailer brakes set and it seemed secure, and looked that way from the side and the handle was in the latched position. But what I had latched to was just the bottom plate of the king pin, and at the 1st bump, or twisting turn they seperated, fortunately for me at low speed in the yard where I hooked up. So I learned to be sure the trailer was all the way down before making the latch, and to crawl under and look to see the jars really are latched around the entire pin.
    truckerdave1970 Thanks this.
  7. puncher
    puncher Medium Load Member
    540
    358
    Feb 12, 2010
    Tn.
    Always and with a flashlight.
    truckerdave1970 and walstib Thank this.
  8. truckerdave1970
    2,987
    3,289
    Dec 15, 2008
    Rochester, NY
    It was a 27' pup trailer with a reefer unit, and it was full of fresh,heavy, weight bread dough!
    I had to crank it up in "low gear" for an eternity before I could get the tractor frame under it and use the airbags to lift it the rest of way.
  9. crzyjarmans
    crzyjarmans Road Train Member
    3,314
    2,441
    Jun 9, 2010
    Home
    i never have to worry about someone else hooking my truck to a trailer, im the only one with a key, i dont and wont ever drive as a team, or slip seat trucking company
  10. end of the road
    end of the road Heavy Load Member
    868
    540
    Jul 4, 2010
    Northern Canada
    I had a similar situation a few years ago. One of the linehaul drivers dropped the trailer in the yard instead of at the airport like it was supposed to be. I got a call at 430am saying that they had a crew of guys waiting to unload. So up I get, head on over to the yard, start the tractor and wait a bit for it to warm up. I think it was -30C or thereabouts. I hook up to the trailer, did the tug test but failed to get under the trailer and ensure the jaws were completely closed.
    As I pulled out of the yard and made a left onto the road I heard something not right and immediately stopped, looked behind me and the trailer was half on and half off the tractor. I tried to crank it back up but couldn't. The entire road was blocked off and I had to wait for the company up the road to come over with a loader to lift the front end up enough to get under it.
    I now always always always check and double check.
  11. Big Don
    Big Don "Old Fart"
    17,996
    35,643
    Sep 8, 2007
    Utah's DIXIE!
    I lost the second pup off a gear one time. But at least it was in the yard, rather than on the road. Real PITA, and extremely embarrassing. Back then we, (city drivers) did the hook ups for the night line haul guys. We did a pretrip and could run them through the shop if there were problems, since there was no one in the shop overnight.
