This one is gonna sound weird
Discussion in 'Questions From New Drivers' started by BostonTanker, Jun 18, 2015.
  1. BostonTanker
    BostonTanker Road Train Member
    1,011
    680
    May 2, 2015
    Boston, MA
    So I was just thinking. What happens if your fuel jells and puts your truck into limp mode or worse? Shuts down your truck completely?
    If I recall, one of the training companies had said they give you tools and give you a space fuel filter incase it happens. So? Does your company provide yoy with such a critical part in case of emergency? I for one can spin a filter and prime a truck. Yes, it does happen especially with the biofuels mandate.
    Thanks
  3. joseph1135
    joseph1135 Papa Murphy
    11,340
    27,299
    Nov 8, 2009
    The Highway To Hell.
    I've never heard of that. I mean, I've heard of fuel gelling but never a space heater and all of that. A decent diesel treatment will protect from gelling, and idle the truck below zero, as most companies will require you to do as to avoid gelling. It can get pretty cold in North Dakota and Minnesota, I've seen wind chills at -40 before. But it's kinda rare.
  4. Snailexpress
    2,675
    6,069
    Apr 28, 2014
    Rocky
    Good question on the middle of the summer.
    S M D, truckon, Swedish Chef and 3 others Thank this.
  5. Oldman49
    Oldman49 Medium Load Member
    353
    300
    Jul 20, 2014
    It's always a good idea to carry a set of spare spin on filters usually from the shop. As far as fuel gel, usually not a problem If you practice safe winter procedures, keep tanks full idle if you can. ( return fuel line is usually 70 deg ) ServicePro 911+ is the best product to un-gel. Seen it work at truck stops.
    BostonTanker Thanks this.
  6. Cranky Yankee
    Cranky Yankee Cranky old ######
    15,317
    209
    Jan 31, 2012
    Green Bay Wi
    one step at a time grasshopper
    you might wanna get hired by a company first :confused:
    most guys that have fuel gell have not taken prevenative measures before hand like buying fuel in GA then ending the day in cold IA low on fuel with no additive
    if you run for a co that has apu's they are usually piped thru the engine keeping everything toasty
    truckon and BostonTanker Thank this.
  7. STexan
    STexan Road Train Member
    14,963
    29,154
    Oct 3, 2011
    Longview, TX
    Lot's of fleet trucks today don't have a spin-on fuel filter that a driver could be expected to replace. Best to make sure the fuel onboard is protected from waxing down to xx degrees as necessary, as a "prophylactic" approach . Or limp to truck stop and pump in some "warm fuel" and let that run through and clear things up.
  8. TripleSix
    130,212
    Some of these people will call for a service truck for a tailight out, and you guys are talking about carrying spare fuel filters.
    One night, when i was a company driver, I had stopped at the Hook in Saskatoon to fuel. I was in the fuel island when the idiot lights came on. The red lights, not the yellow ones. I popped the hood and noticed in the plastic domed fuel filter that ice crystals were forming. I left the engine running and got a gallon of kerosene. Put a little in the filter bowl and the rest in the fuel tanks and it ungelled.
    Thing is, the company had strict rules about no additives in the fuel tanks. They said that the treated fuel up north would be enough. It wasn't. In fact, there were quite a few service trucks in the parking lot. I take my survival over any company policy.
    passingthru69 and BostonTanker Thank this.
  9. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,768
    Mar 5, 2012
    Ontario Canada
    Just FYI .... up here in Canada you do not need to add any additives ... the fuel is actually treated from the pump. Not just down to 20F or 0F or whatever. I run Canada all winter and never put any in and never have any issues with fuel gelling.
    That isn't to say I don't carry extra fuel filters and fuel in a can to change if necessary when I'm burning US fuel. Been using Howe's and idling when its very cold and haven't had a problem since 2008 when I was new and learned the hard (expensive) way. (happened in ND with MN fuel)
  10. TripleSix
    130,212
    Sure looked like a bunch of Canadian trucks gelled up that night mine gelled up.
  11. dca
    dca Road Train Member
    6,834
    11,427
    May 31, 2011
    Earth
    You're on your own, and responsible
