those with company trucks and 400w inverters
Discussion in 'Swift' started by AZS, Feb 19, 2011.
  1. AZS
    AZS Honk if anything falls off
    2,912
    1,303
    Sep 30, 2010
    PHX, AZ
    Do you leave your things plugged in all the time? laptops plugged in etc. While I'm asking about that what about 12v coolers? Keep them running no matter?
  3. rocknroll nik
    rocknroll nik High Risk Load Member
    4,490
    5,770
    Oct 18, 2008
    can't read the sign
    the only time I unplugged was when I was on hometime......of course I didn't drive for swift
    AZS Thanks this.
  4. AZS
    2,912
    1,303
    Sep 30, 2010
    PHX, AZ
    Any input is appreciated.
    rocknroll nik Thanks this.
  5. hkerekes
    hkerekes Bobtail Member
    10
    Jun 12, 2010
    I leave mine plugged in all the time and i have a 12v waeco cooler that stays plugged in as well.
    I have had no issues with the shop or the truck what so ever.
  6. bowlwinkle
    bowlwinkle Heavy Load Member
    824
    704
    Aug 27, 2008
    Ankeny, IA
    I leave my cooler plugged in all the time unless I'm on home time. I usually unplug the inverter unless I'm using something, but not sure it matters.
  7. rocknroll nik
    4,490
    5,770
    Oct 18, 2008
    can't read the sign
    I had two 400 watt inverters and the coleman 12 volt...and the batteries only complained after 12 hours if I wasn't running the truck.
  8. Roadmedic
    Roadmedic Road Train Member
    18,951
    8,981
    Apr 4, 2007
    Left my cooler plugged in for a couple hours once.
    Had to jump the truck.
    The company had no sympathy for drivers that left them plugged in and had to pay for jumps.
  9. rocknroll nik
    4,490
    5,770
    Oct 18, 2008
    can't read the sign
    Last truck I had did something like that too Medic...turned out the cooler was going bad ....it was drawing to much power....unplug the cooler and away I went
  10. Roadmedic
    18,951
    8,981
    Apr 4, 2007
    My company sent me on a load to St. Louis with a leaking power steering pump. They did not have time for the mechanic to fix it, but yet, I could drive it down there and sit and wait for 5 hours before the shippers appt.
    So, they asked me to change it.
    Like a rookie, why not.
    It took longer, because two of the bolts stripped off and I had to get the mechanic to come out anyway. Meanwhile, forgot the cooler.
    Jump required. Thankfully, they were okay for one time, since I had tried to fix the truck.
  11. bluebonn
    bluebonn Road Train Member
    1,026
    723
    Aug 21, 2010
    Texas
    I work for Swift but I am too poor to own a cooler.:biggrin_25523: I do have a inverter to power a few things but I always UN plug it when I am done with it.
    spuddatruckdriver Thanks this.
