Thoughts on a Day-use AG truck
Discussion in 'Ask An Owner Operator' started by TripleNickle, Feb 12, 2019.
  1. TripleNickle
    TripleNickle Bobtail Member
    17
    5
    Aug 26, 2018
    Hey all, I would love to hear any thoughts you have on this truck. I'm looking to buy a truck and start hauling AG here in the Central Valley (CA) later this year when harvest starts in earnest. I really only need a daycab, but the idea of having a small sleeper has always really interested me as there are some times when going overnight can be lucrative (like running up to Oregon for Onions).
    Single axle only needed as the hoppers/flatbeds I'll be mainly hauling are doubles, but they are almost always max weight (80k-90k, depending on the product/farmer).
    Thinking Freightliner might be a good starter truck as the parts are cheaper and easier to obtain, from what I've read. I can do some of the more routine maintenance myself, leave the big stuff for the mechanic.
    Anyway, all thoughts/questions are appreciated! Thanks!
    https://www.truckpaper.com/listings/trucks/for-sale/30413435/2014-freightliner-business-class-m2-112
  3. TripleNickle
    17
    5
    Aug 26, 2018
    I should add that I've mostly been looking at trucks in the $30k range, this is on the higher end of my price range for sure. Seeing as I won't be purchasing anything for likely 3-4 months, I doubt this exact truck would be available still. But I want to make sure I'm not missing obvious questions...
  4. JPenn
    JPenn Road Train Member
    1,829
    1,874
    Mar 5, 2008
    Northern Tier PA
    That's a cute little rig. I like the micro-sleepers myself, kind of a modern take on the old coffins. For those times when 99% of your use gets home, but every now and then an overnight happens.
    Oxbow Thanks this.
  5. Cummins610
    Cummins610 Bobtail Member
    6
    May 6, 2018
    My opinion don't go with the medium chassis trucks like a M2 unless there is a great benefit to running the single axle(such as licensing), your best option is a true Class 8 truck. Much easier to work on/way cheaper parts and longer service life
    Socal Xpress Thanks this.
  6. TripleNickle
    17
    5
    Aug 26, 2018
    Cute wasn't exactly what I was going for, haha!
    The single-axles are all the subhaulers (and company trucks too) use around here, there's just no need for a tandem back there. Saves tire wear with no real benefit.
    Why do you call the M2 a Medium chassis? It's rated at 450 hp. Though, now that I look closer it doesn't specify that it's 80k GVWR, which I would need....
  7. TripleNickle
    17
    5
    Aug 26, 2018
  8. REO6205
    REO6205 Road Train Member
    13,168
    60,508
    Feb 15, 2014
    California.
    A lot of California ag hauling pays by the ton. The weight of that sleeper might wind up costing you quite a bit of money by the end of the season.
    Look at Panella and Lowrie and Button and all the rest of the ag haulers...they have it figured out.
    beastr123, Oxbow and stwik Thank this.
  9. azheavyduty
    azheavyduty Medium Load Member
    345
    1,108
    Jan 11, 2011
    Glendale, AZ
    Who are you looking to pull for? Hauling what? When I was young and money hungry I always got an extra load per day during grapes because i would stop by home and take a shower then head to the first pick up to sleep. First there, first load. Early to the winery meant less waiting.
    Oxbow Thanks this.
  10. TripleNickle
    17
    5
    Aug 26, 2018
    Tigerlines, Antoninni, Panella, Valley Farm, others. Hauling tomatoes, green/dry/milled rice, onions, peaches, probably others as I get deeper into industry connections.
    I hadn't thought about the weight of the sleeper being an issue. Because yeah, for a lot of what I'm looking to do it's paid by weight. I can't imagine a micro sleeper adds very much, and doing AG you run over max weight a lot... but a sleeper might just be pushing the issue. Dunno.
  11. TripleNickle
    17
    5
    Aug 26, 2018
    Lowrie and Button don't seem to do a lot of sub-hauling from my observation. I haven't called them to find out but might in the future. Talked to plenty of company drivers from both.
