Hi all,
I have never owned a cat before,
Any reviews on it?
I know it costly to maintain,
Any pros and cons for it?
It belongs on a 94 ext peterbilt 379 with roughly about 690 thousand miles.
Coming from a 12.7 d60
Any help and comments will be greatly appreciative. Thanks
thoughts on CAT c15 engines?
Discussion in 'Ask An Owner Operator' started by Mrnice81, Jun 10, 2014.
They are all costly to maintain. If that's a factory engine in that truck it's gonna be a 3406e Not a c15 but it's still a good engine. For what I need it's the only way to go compared to a Detroit.
If you haul light loads you will probably get better mileage with the Detroit but the cat can handle heavy loads and hard pulls better in my experience with the two.Mrnice81 Thanks this. -
If you're going to be 80k and below either would work, obviously cat would pull better.
Thanks. .. so 3406e it is..... the owner said it is original c15 550, I ask for the serial number on engine, he says the piece of metal flew off from pressure wash..... should I be alarmed to buy it?
Is there any other way I can find out about the engine? If it is original or not?
The asking price is 29,500,
but I highly doubt I will be paying that much. -
Heavy loads around 40k to 46k. ... i have a hard time climbing hills now with my detroit. It's like an auto tranny. .... -
No I wouldn't be alarmed with it. Get the last 6 of the vin and call peterbilt. They can give you the serial number. C15 didn't come out for another 5 years or so after but there's not much difference between the two. A lot of parts are interchangeable.
I'm not sure about how to go about verifying that to be original engine without the plate. The part number on the block could tell you what block it is but someone else will have to tell you where it's stamped. The early 3406e and petes had radiator mounts across the top of the head and over valve covers and the later setup had the radiator brackets bolt to the front of the headMrnice81 Thanks this. -
I'd be leary of it just based off the fact the owner doesn't even know what kind of motor he has, or is outright lying about it being a C15 for some silly reason. Price is outrageous for a 1994 hood. It'd have to have lots of new parts everywhere and an inframe with paper to command a premium like that. If he doesn't even know what the motor is do you think he took care of that truck? To me it speaks of someone who could care less when they don't even have a clue the serial number of their motor. I know mine same as my social security number. Serial number is on the block so the plate missing is not a big deal. Trucks from the mid ninties are a dime a dozen.
Mrnice81, Cetane+ and poppapump1332 Thank this. -
The radiator brackets isn't a guarantee either way but if it has the bracket over the valve cover I would bet it's an original 3406e
You pu have to understand most people don't know there's a difference between the two and it's been 14 yrs since it was called e model. Most just want a big cat and c15 is easier to remember. He probably paid someone to fix it and never questioned the parts someone said it needed. I wouldn't be nervous about it knowing most people driving don't even know what they have.Mrnice81 Thanks this. -
Sounds to me like the classic guy who just picked the truck up for a song and a dance and is trying to hit a home run on a flip. If it were a well maintaned one or two owner truck than I would say its worth it, but I would be a little leary on this one. People driving may not know anything about what there in but an owner should.
