Thread strip coming off tire, help me find the cause?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Greggg, Apr 25, 2019.
  1. Greggg
    Greggg Light Load Member
    161
    35
    Jun 30, 2018
  3. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,137
    Mar 5, 2016
    White County, Arkansas
    Those tires have had more than enough, combined with the cupping that says supension or alignment issues making it worse. Replace them. And fix the original problem in the structure.
  4. boneebone
    boneebone Road Train Member
    2,296
    2,367
    Mar 13, 2009
    Worn suspension parts and/or worn shocks.
  5. Greggg
    161
    35
    Jun 30, 2018
    Ah ok. I had a break chamber issue on the axle right behind those tires until then those tires had been fine and it just started after that incident.
    You guys think it could have anything to do with that ?
  6. bryan21384
    bryan21384 Road Train Member
    14,926
    32,370
    Sep 18, 2009
    Memphis, TN
    Age of tire maybe
    Heavyd Thanks this.
  7. Scottyotty1
    Scottyotty1 Light Load Member
    65
    108
    Apr 19, 2019
    If it's on the inside or outside of a steer Tire it could be the alignment on the front axle or only on the rear axles or it could be a bad shock. It could also be parts such as tie rod or kingpins if it's on the trailer and on the inside it's usually a bad shock. A reputable shop that does triple Axl alignments will be able to tell you
  8. Greggg
    161
    35
    Jun 30, 2018
    Ok thanks it’s on the front trailer axle passenger side it started with the inside tire then outside started getting bad as well
    Scottyotty1 Thanks this.
  9. Scottyotty1
    65
    108
    Apr 19, 2019
    I would have the shocks checked and make sure your leveler is working correctly for your airbags
  10. Scottyotty1
    65
    108
    Apr 19, 2019
  11. Scottyotty1
    65
    108
    Apr 19, 2019
    That may be a possibility but I would go with shocks or air bag leveler on a trailer but like I said have somebody reputable check it I've seen stranger things cause tire wear
