I have a 2006 VNL. I lost my throttle and cruise control. It happened while parked and the engine was off. Started the truck and it just idles. Any suggestions would be great.
Throttle problem
Discussion in 'Volvo Forum' started by Rick1227, Aug 30, 2013.
ck wire at foot. has plug in/ wet?
Checked it today. No wetness or corrosion. I am stumped.
check the fuse for cruise control
follow foot wire next con. on fire wall. T.P.SEN. bad $46 or 50 at parts store
check datalink (J1708) and CAN (J1939). check VECU fault codes.
Hello, i have similar problem with FH12 D12D 500 but a bit different is while the truck is running have to keep playing the idles accelerator, when you press and hold the idles at 1300rpm (or anly rpm) it will reduce like release the foot pedal but you dont. Idle come again when press and depress for few times.
already replace the pedal potential sensor, wiring... there is no faulty codes.
someone suggest repalce the VECU. is that true ?? -
Different problem, bad gas pedal sesndor
Can not find a fuse labeled for the Cruise Control. Plus I do not have any blown fuses.
How can I reset the Data Link error?
