Throttle sensor
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Howard38, Feb 3, 2016.
  1. Howard38
    Howard38 Bobtail Member
    4
    I was driving down a highway and my pedal stop working.i have a n14 cummings in a 98 peterbuilt.put it on a computer and told I needed a new throttle sensor so I replaced it and still the same problem.the sensor has two bolts that bolt it to the pedal,but if I remove the bolts and turn the sensor counterclockwise the engine will throttle up like it is surpossed to but when I press the pedal I got nothing,I am just wondering if the pedal itself can go bad
  3. Oxbow
    Oxbow Road Train Member
    13,387
    138,746
    Nov 24, 2015
    I don't know anything about drive by wire pedals, but I suppose it could have a rheostat sort of affair that the sensor reads?
  4. Howard38
    4
    I am still not sure if it has to be recalubrated r not because it it a new sensor
  5. Slowpoke KW
    Slowpoke KW Road Train Member
    1,170
    12,826
    Dec 7, 2015
    OK
    To check the pedal operation just remove the sensor and make sure the tab that operates the sensor moves when you push the pedal down. Assuming the sensor is mounted properly and making good connection at the plug I'm not sure what else there could be
  6. Slowpoke KW
    1,170
    12,826
    Dec 7, 2015
    OK
    That sensor is just a potentiometer to the best of my knowledge there is no calibration that can be done
  7. Cory wood
    Cory wood Medium Load Member
    335
    162
    Nov 7, 2015
    Sounds like the tab that the pedal actually turns has broken. If it's revving when you do it manually that has to be the problem. It's CUMMINS there is no such thing as a Cummings
    Slowpoke KW Thanks this.
  8. Bean Jr.
    Bean Jr. Road Train Member
    5,551
    9,897
    Mar 30, 2014
    It's in a Peterb(u)ilt, that's why!
    Slowpoke KW, SAR and Oxbow Thank this.
  9. Cory wood
    335
    162
    Nov 7, 2015
    Oh yeah that's what I was missing
    Oxbow Thanks this.
  10. boneebone
    boneebone Road Train Member
    2,297
    2,371
    Mar 13, 2009
    Yes, the Pedal can get "play" in it and the Sensor can not read it properly.
    I would replace the Pedal and your problem will be solved.
    Some Truck Manufactures sell the Pedal with a new Sensor included with it too.
    Oxbow Thanks this.
