Throttle sticks ?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by AUSSIE DAVE, Sep 2, 2012.
  1. AUSSIE DAVE
    AUSSIE DAVE Road Train Member
    1,032
    176
    Feb 21, 2010
    OZ - Brisbane
    2005 Freightliner Argosy 14L series60 pre egr , on occasion when I change gears(no clutch) the engine RPM do not drop and I have to push the clutch in then the RPM drop, any ideas ? :biggrin_25512:
  3. tank4life
    tank4life Light Load Member
    155
    105
    Feb 18, 2012
    WIth an electronic computer controlled engine I don't believe the throttle can stick. If the fuel system is sucking air it will create a sympton similiar to the throttle sticking. The engine will not want to idle down. Check the fuel system to make sure that it is not sucking air.
  4. lucky07
    lucky07 Light Load Member
    197
    118
    Jan 15, 2012
    Ottawa, ON
    RPM does not drop at all or doesn't drop all the way?
    Before or after you've pulled out of gear?
    If pressing the clutch works to bring it down does it feel the same as when you use the clutch to take the truck off high idle?
    Cruise control?
  5. ralph
    ralph Road Train Member
    1,112
    632
    Mar 1, 2009
    At The Key Board
    Clutch switch?
  6. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,044
    May 13, 2011
    Middle Tennessee
    Remember when they sold throttle sticks at truckstops?
    I remember they were chrome and had red rubber tip.
  7. AUSSIE DAVE
    1,032
    176
    Feb 21, 2010
    OZ - Brisbane
    There is a fuel leak that I degreased and I'm in process of fixing, thanks for the info
