Thumping and ch-ch-chugging at 1200-1500 rpm
Discussion in 'Volvo Forum' started by Vanleu22, Jan 2, 2024.
  1. Vanleu22
    Vanleu22 Bobtail Member
    5
    4
    Aug 26, 2022
    Hi Folks,
    Please help me get some insight into this issue I have.
    2016 d13 del'd I-drive
    Between 1200 and 1500rpm, while accelerating, climbing or pulling a trailer, and more recently even just going down the road, I hear and feel a "thumping". Some describe it as a knocking or 'put put put'-ing. It is not very prominent when bobtailing, and not present while just idling and revving the vehicle. I just had an overhead done which did not improve the issue. Some drivers have experienced worn cams to be the issue, but my mechanic took a close look at the cam today and didn't detect any wear. He then said it might be a torque converter issue. Another mechanic said the automatic doesnt have the torque converter and that some cam wear is not detected by naked eye and will need the cam to be mic'd (sp?). Most recent service included an oil change as well as a replacing faulty sensor at the transfer case which caused involuntary engine shut downs. I'd like to upload a video of the sound but i dont know how
  3. uncleal13
    uncleal13 Road Train Member
    3,797
    6,294
    Apr 9, 2009
    Humboldt, Sk
    Correct , an autoshift transmission (iShift, Eaton Ultrashift) still has a clutch that the computer operates but doesn’t have a pedal. An Allison transmission is an actual automatic like a car and does indeed have a torque converter.
    JB7 Thanks this.
  4. QUALITYTRUCK
    1,802
    1,763
    Jun 14, 2009
    romulus,mi
    If the same mechanic that said "it might be a torque converter issue" did the overhead you better consider taking your Volvo elsewhere for service. I don't know what your issue is with without seeing your truck.
    JB7 and AModelCat Thank this.
  5. Vanleu22
    5
    4
    Aug 26, 2022
    No, 3 separate mechanics. Overhead was done on the road in El Paso. Second mechanic in MD did additional diag and inspected cam and suspected torque converter issue. Third mechanic working on another truck of mine in TN mentioned over the phone no torque converter is present.
    So far I'm no further than where I started
  6. North Pole Nightmare
    North Pole Nightmare Heavy Load Member
    840
    1,632
    Dec 15, 2021
    Any play in the carrier bearing?
  7. Vanleu22
    5
    4
    Aug 26, 2022
    Mint
  8. nasriza
    nasriza Road Train Member
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    Start from simple ####, I would start to check with leveling valve, to make sure ride height is proper sounds to me like driveline is out of angle, so check leveling valve or replace before anything and go from there.
    Vanleu22 Thanks this.
