Thumping floor
Discussion in 'Trucks [ Eighteen Wheelers ]' started by durallymax, Feb 15, 2015.
  1. durallymax
    durallymax Medium Load Member
    318
    97
    Jan 30, 2011
    Wanted to try quieting down our fld120, so I put dynamat and liner on floor and back of cab. Still need to do the rest but the floor thumps a lot with a very low pitched loud rumble when the motor is under load between 1400-1 600.
    Haven't found anything loose or rubbing. What else should I be looking at. Thanks.
  3. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Engine mounts prob worn out. Steel to steel.
  4. billandlori
    billandlori Medium Load Member
    357
    107
    Sep 5, 2010
    Stratford, Ontario, Canada
    Check your cab mounts too, mine were on steel and made lots of noise!
    Bill
    bullhaulerswife Thanks this.
  5. x#1
    x#1 Road Train Member
    1,773
    1,104
    Dec 24, 2009
    Cherokee County, Alabama
    an exhaust leak perhaps?
  6. durallymax
    318
    97
    Jan 30, 2011
    I was wondering about the mounts. I'll have to look close at them or just swap them and see. It's old enough, probably needs them anyways.
    Exhaust is brand new and not contacting cab anywhere nor is any piece mounted to cab
  7. bullhaulerswife
    bullhaulerswife Forum Leader/Admin Staff Member Administrator
    28,283
    44,414
    Jul 23, 2007
    Midwest
    Check the cab mounts and also the cab shocks. We replaced both and it really helped. At one point one of the shocks was rusted and frozen into place and made the truck "tilt" which in turn chewed up one steer tire all the time. Once we got that fixed, the tire issue went away with the noise.
    billandlori and x#1 Thank this.
  8. kwforage
    kwforage Road Train Member
    1,047
    472
    Jun 3, 2007
    Wisconsin
    Look at new mounts from Atro instead of OEM.
  9. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    Motor mounts most likely. If you get a lot of thumping when hitting bumps, check those hood cones on the firewall.
  10. durallymax
    318
    97
    Jan 30, 2011
    Hood is very tight, that was another thought, no extra thumping on bumps really.
    Cab shocks are new.
    I'll start with motor mounts.
    Thanks.
  11. 062
    062 Road Train Member
    6,208
    33,439
    Oct 20, 2013
    Also look at your bellhouseing,mainly around the mounting bolts. Look for cracks or any shiny metal. Seen dump truck where bolts were over torqued,galled the threads they were holding but not tight.
