I've been through heavy thunder storm with tornado warning last night (I-80 NB).
I stopped at couple of truck stops and rest area but no parking spots
so I had to drive till midnight.
I've met heavy rain, hales,lots of lightnings,and strong wind on the way.
I was wonder that strong wind can really cause an accident?.
Did it ever happened before?
thunder storm and tornado
Discussion in 'Questions From New Drivers' started by hungrywolf, May 23, 2007.
Page 1 of 3
There are numerous reports of high winds causing accidents on the highways not only for regular passenger vehicles but ALSO for big rigs, high wind warnings for high profile vehicles are posted frequently by the NWS.
A 60 mph wind can flip a trailer. If the roads are slippery, lesser winds can cause a jackknife or blow the trailer tandems off the road.
An empty trailer? Or does it have to be top heavy to start with?
80 doesn't go north
And yes the wind can blow a trailer over.
NE has a lot of truck stops, more than many other states. If you have a up to date truck stop directory look for one of the smaller ones. I seldom had parking problems across NE, but some times I had to park at one of the 12 slot stops. -
Both. I've seen lots of trailers wheels up across WY. I've even seen empties in a parking lot on their sides. Eastern WY gets a LOT of wind some times. Chicago is called "the windy city" but Cheyenne and Casper both get far more wind than Chicago. -
I was on US56 about 2 years ago east of Ft. Dodge, Ks. I got hit broadside by I would estimate a 50mph gust. I had 44k of aluminum lids on in low pallets. I watched my trailer tires lift about 2 foot off the ground and felt the truck actually start to twist on the 5th wheel. I thought for sure I was toast! I just kept the throttle full down and hoped it would settle back down and it did.
I got into Ft Dodge and parked until evening. I changed my shorts too.
I think the only reason I didn't go over is because the pallets were so short. If they had been taller, the center of balance of my truck would be been much higher and there is no way I would have stayed upright.
I gained a serious respect for high winds after that little fiasco -
Ive seen trailers in the Texas Panhandle go down the road w/tandems on 1 side off the pavement. Watch I 25 thru NM in the spring. El Cajon is a baddie, lots of turnovers there from wind. I've seen pebbles the size of peas take the paint off around Edwards AFB. Hope you have dry pavement and a tailwind.
I have gone through Ill, and had the wind push me around a little, made it hard to stay in my lane. The same night 2 Trucks was flipped in New Mexico. That was many years ago.
After living in WY for 12 yrs where over 50mph winds during the late fall, winter and spring are common I am going to say that you got hit with a gust FAR harder than that to do to your rig what you said happened.
Page 1 of 3
