Ti-Brook vs. Travis end dump
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by herbiemin, Nov 1, 2015.
  1. herbiemin
    herbiemin Light Load Member
    94
    50
    Dec 20, 2014
    We are looking at buying an end dump for our farm. We are going to try to look at a couple tomorrow. One is a 1991 32' Ti-Brook electric tarp, alum wheels, spring ride; and the other is a 1992 35' Travis end dump. It has new brakes, drums, brake chambers, and 90% tires. Is there a huge difference between the two models? They are both a little shorter than I'd like, would like a 39 or 40'. Is it going to be too hard to get your weight on a shorter trailer if we end up hauling for someone else? And are there any major quality differences between the two that we need to be aware of? And if the trailers are basically equal, is air ride suspension worth $5000? I have pulled air ride and spring trailers in a chain floor but never in an end dump. Thanks
  3. mountaingote
    mountaingote Road Train Member
    2,026
    7,916
    Sep 22, 2012
    If you get air ride make sure you dump the air before you dump the load. They like to tip over
  4. sparky88
    sparky88 Light Load Member
    143
    31
    Jan 22, 2014
    oswego, ny
    I would lean towards the one with air ride. Depending on the other dimensions. If they are both the same width and height then the 35 ft gives you more room. And plus you can dump the air and makes it more stable. I would imagine the springs would still give you more wobble when going up in the air
  5. 59MackB61
    59MackB61 Light Load Member
    196
    165
    Sep 12, 2012
    Ride quality is better with air that is important especially since did not say what you were going to pull it with
    if ride quality is not important springs will be fine especially if it will sits since maintenance issues would be less
  6. SVERG
    SVERG Bobtail Member
    7
    Jan 31, 2016
    Ti brook all the way
