2015 cummins isx 2350 there's a ticking noise going on i can hear it when the truck is idling it sounds like it's coming from the oil pan/transmission area. Its not very loud but you can hear it. What is this?
Ticking cummins isx
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Petegraintrain, Nov 19, 2021.
If it’s from the top of the motor it’s the camshaft getting a flat lobe
not sure what to suggest if it’s from the flywheel areabzinger and Rideandrepair Thank this. -
Rideandrepair Thanks this.
Are you certain its from the engine? Does it make the noise, clutch engaged/disengage or change at all? Does the noise change or go away under load or with engine RPM? If so what RPM. Does it disappear off idle?
Big Road Skateboard and Rideandrepair Thank this. -
Probably just the clutch/ throw out rattling- Lube everything and make sure its adjusted and run it????
Rideandrepair Thanks this. -
Maybe take the inspection cover off the bottom, see if noise gets louder. I had mine running that way after doing the clutch. Couldn’t believe how much noise it makes. Made a video, thought I had a problem. Lol. Maybe it will help identify the noise if it is the throwout.
On mine it meant the cam was getting a flat lobe at 228000 miles after a complete inframe .
Of course Cummins took no responsibility for it because they didn't do the work.
And I ate the bill to the tune of 6k.Rideandrepair Thanks this. -
bzinger Thanks this.
