Tie downs for under trailer dunnage Storage
Discussion in 'Flatbed Trucking Forum' started by Kansas, Jul 26, 2012.
  1. Kansas
    Kansas Road Train Member
    2,541
    2,585
    Apr 14, 2009
    aircap, Ks.
    I'm using rubber tarp straps, but have never feelt like the 4x4's were secure enough. I've also used the throw away elcheapo 1" ratchet straps, but those are a hassle, and 2" just seems to big.
    My rack is just 1x1" square tubing welded under the trailer frame with stops welded on the ends.
    Stopping short of switching to an actual basket. Whats a better way?
  3. grizzly
    grizzly Medium Load Member
    599
    432
    Aug 27, 2008
    Layton, Ut
    Bungees or tarp straps are illegal to secure dunnage and will get you a ticket. I use the 1" ratchet straps, but I buy good ones.
  4. Pedigreed Bulldog
    7,737
    14,421
    May 7, 2011
    Short piece of 1/4" chain and a snap binder always worked well for me...
  5. AZS
    AZS Honk if anything falls off
    2,912
    1,303
    Sep 30, 2010
    PHX, AZ
    underneath?
    I just use a bright orange (since dottie loves to look for this) one inch strap and ratchet I got at walmart. Has a 350 pound rating on the tag.
  6. MrEd
    MrEd Road Train Member
    2,196
    2,836
    Sep 2, 2011
    Winfred, SD
    the state of kansas is pretty particular about that. i used to work for a company, that like many, carry the 4x4's on the landing gear supports. if they are only secured with bungies in kansas the fine, at least then, was 75 bucks. may be more now, and i am sure kansas isn't the only state that makes an issue of it.
    dirtyrabbit Thanks this.
  7. Kansas
    2,541
    2,585
    Apr 14, 2009
    aircap, Ks.
    I was looking at poultry binders, but I'd have to order a set just to find out if they would work. Or maybe even the little spring load binders with a short piece of chain.
    Im also considered using some of the E track ratchets w/ a doubler to tie the two ends together.
    Ill probably just order some decent quality 1" endless ratchet straps.
  8. schmud0811
    schmud0811 Medium Load Member
    379
    283
    Jun 2, 2010
    Phoenix,AZ
    check out a company called snap loc. I bought a couple hundred of their kits for our flatbed trucks. Might fit your application http://www.snaploc.com/
    Kansas and CAXPT Thank this.
  9. SHC
    SHC Spoiled Rotten Brat O/O
    8,484
    7,046
    Feb 26, 2011
    Westville, IN
    I use a 2" wratchet strap from TSC. It was on sale for $9.99 and works just fine
  10. Autocar
    Autocar Road Train Member
    3,167
    2,358
    Apr 28, 2012
    The Hot Rod Shop Oxford, AL
    I use the heavier duty 1 inch ratchets from Walmart, that I buy in four packs. They do have a WLL, so they are acceptable to the DOT. They work good for tarping too!
    You definately do not want to use bungees to be primary securement anything, but tarps. That will not only get you a citation, but also some CSA points.
    SHC Thanks this.
  11. Quickfarms
    Quickfarms Heavy Load Member
    898
    236
    May 29, 2012
    Los Angeles, Ca
    Interesting design.
    A little expensive until you look at there truck and trailer pack
