Tiedown Ropes
Discussion in 'Experienced Truckers' Advice' started by Tb0n3, Jan 14, 2023.
  1. Tb0n3
    Tb0n3 Road Train Member
    4,738
    9,654
    Oct 5, 2012
    Earth
    Is there anyone still alive today who used to tie down loads with ropes and knots? I heard tell that my grandfather used to secure things in a dryvan with ropes tied to a rail. I imagine agricultural would be more likely to use ropes over the years than big heavy loads that would be chained down. With the so-called truckers hitch it really seems like you can get a rope pretty tight. Looking at the WLL on nylon and polyester half inch ropes they're as good as 2-in ratchets. 4000 lb versus 3333.
    I'm not interested for any real practical reasons, just curiosity.
    beastr123 and D.Tibbitt Thank this.
  3. Dennixx
    Dennixx Road Train Member
    4,548
    14,624
    Feb 13, 2010
    twin cities
    Bedbuggers and furniture delivery used cotton straps tied off to interior rub rails.
    No cinching methods other than knots that would tighten with tension and were released with a tug on the loose end. tie_webbing_full.jpg
    Lonesome and tscottme Thank this.
  4. kemosabi49
    10,977
    47,918
    Jan 13, 2013
    SW Arkansas
    I worked for a company loading sheetrock on trucks in the late 70s early 80s. There were a few truckers that used ropes with those truckers knots. Mostly on skids of mud or bagged plaster, but sometimes on the sheetrock too.
  5. wis bang
    wis bang Road Train Member
    3,456
    4,100
    Jan 12, 2011
    Levittown, PA
    Had an opportunity to move a few flatbed loads of plant materials being shifted from the closing plant and catalyst being returned to the manufacturer. With a borrowed flatbed and two owner operators that came from flatbeds to tanks. They loaded super sacks and put on the sketchy side kit and tarped the top.
    I watched them re-doing the tarps placing a rope in every other eyelet and tarp straps in the others. I learned that the rope limited the over all movement of the tarp by limiting how much the straps could extend in the breeze.
    Growing up, the town has a rope walk and dad always had a hank of 1/2 inch Manila behind the seat in the pickup.
    He avoided it but we always ended up doing 'favors' moving stuff for friends. Dad's imagination would Tetrus everything in place and start in with that rope ending with a rolling hitch.
    We never lost anything.
    rank, kemosabi49, beastr123 and 2 others Thank this.
  6. Numb
    Numb Crusty Curmudgeon
    4,324
    10,272
    Jan 30, 2012
    Charlotte, N.Carolina
    hauled sock machines in a van in the 80's, secured with rope, then I saw a competitor using straps and E-track.
    I was like WOW, we need this.
    talked the company into installing it. still carried ropes though up until they went under in 2000.
  7. wichris
    wichris Road Train Member
    4,504
    9,277
    Jan 17, 2011
    Used rope all the time on tile and rolled roofing early 80's
    JoeyJunk, Diesel Dave, Numb and 2 others Thank this.
  8. wis bang
    3,456
    4,100
    Jan 12, 2011
    Levittown, PA
    Containers have tie down points. I've see web strapping with metal tension clips, plastic banding and similar used when the container load does not cube out.
    I used to manage a rail to truck yard where we received a lot of 20 foot cans loaded with a huge plastic bag of polystyrene pellets that we transferred into a customer's railcars before trans-loading and delivering the product.
    The tie downs were connected to the bag by white nylon line around 1/4 inch and stainless steel 'clips' into the hold downs.
    That was in the late 90's and despite giving hundreds of 'em away, I still have a bunch of those clips and if I look, I'd bet I still have some of that line too.
    We had an old tractor with a Bartlett high lift. The guys cracked one door part open pulling the bag neck into a box and chaining the doors before cutting it and hooking up the hose. As the machine ran they would raise the front until the tail lights pointed down and the bag went empty.
    Then we has to strip the bag, line and clips,
    JoeyJunk, Lonesome and Numb Thank this.
  9. Kshaw0960
    Kshaw0960 Road Train Member
    1,581
    5,025
    Jun 17, 2018
    I bought like 300 feet of thick stretch cord 3/8” maybe and that’s how I did my flatbed tarps instead of bungees. Cut them into maybe 35’ sections and leave it permanently in the tarp d rings. Much quicker and easier.
    Problems with rope is the WLL is so low even on half inch rope that a 2” strap is higher. Don’t know what ropes you’re talking about.
    JoeyJunk Thanks this.
  10. dptrucker
    dptrucker Road Train Member
    4,705
    3,242
    May 14, 2012
    adelanto,ca.
    I always see guys hauling hay or pallets using ropes
    Lite bug and JoeyJunk Thank this.
  11. High Stepper
    High Stepper Medium Load Member
    663
    11,533
    Jun 8, 2022
    Square One
    LTL companies still use rope for securement in certain situations. With so many random products on a trailer, a strap or load bar isn't always the best choice.
