tight lots
Discussion in 'Experienced Truckers' Advice' started by Jackknife1016, Aug 19, 2012.
  1. Jackknife1016
    Jackknife1016 Bobtail Member
    21
    8
    Jun 21, 2012
    Hey how's it goin guys..I'm pretty new to driving, been with transam for about 3months. I'm a pretty decent backer for my experience but I have a problem on those tight spots where there isn't Alot of room out in front of you, It just seems like however I set up for it I always run out of room up there and the front of my tractor will come around and hit on whatever is out front. Any advice on setting up or just backing in those conditions? Appreciate y'all be safe!
  3. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    Experience, experience, experience ...
    Red Hot Mess Thanks this.
  4. STexan
    STexan Road Train Member
    14,963
    29,156
    Oct 3, 2011
    Longview, TX
    Some new drivers tend to feel they need to get the trailer "aligned parallel" with the slot BEFORE the rear of the trailer actually enters the slot. With proper setup and approach configuration, you can enter the slot with some angle still left to straighten out. I'm not saying this is what's going on or where you're going off the beam but it's a possibility and a misconception many have to deal with. But there are a lot of other things to consider and each situation is a little different.
    Ditto the practice and gain experience post. It's hard to discuss backing concepts and strategy in a message. It's about how well you can visualize how the procedure will play itself out as you back and get under and about where the tractor bumper will be along the way ... beginning from a given setup.
    CAXPT and 3 Dog Nite Thank this.
  5. sdaniel
    sdaniel Road Train Member
    5,511
    4,420
    Sep 7, 2011
    Pelham N.C.
    Some real tight spots, you can slide your axles. A pain but if you can not get ends to line up move the ends. Axles all way back can really make a difference. All but solves tail swing. Just don't hit anything! And don't let people rush you. Get good then may be fast.?
  6. gokiddogo
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    Good advice on not letting people get to you. I don't care how angry other drivers are at how long it takes you to back it in beside another truck. Turn the radio right off if you have to. Just please don't hit my truck. Get out and look 20 times if you feel you need to. Never try to do it fast, that is not showing off or being professional. Taking that extra few minutes can save you a HUGE problem if you hit another truck.
    58Skylane, CAXPT and Red Hot Mess Thank this.
  7. MNdriver
    MNdriver Road Train Member
    7,985
    4,372
    Feb 24, 2012
    you can go into a spot at and angle and then cut the tractor to make it parallel. I have had inches to the truck on my right and when I was done, I was a good 2 feet away from them. It scares the crap out of the driver next to you, but an inch is as good as a mile then.
    It's also nice when the guy in the trucks next to the hole also get out and actually help you.
  8. 58Skylane
    58Skylane Medium Load Member
    388
    276
    Mar 31, 2012
    Cody, WY
    X2!! What you said ^^^^^^
    We were all rookies at one point in our careers. Heck, I still get stumped trying to back into some tight spots myself.
    Red Hot Mess and CAXPT Thank this.
  9. Russjac
    Russjac Light Load Member
    196
    68
    Apr 3, 2012
    Las Vegas
    I got the same amount of experience as OP, about 3 months, and backing has been my biggest challenge. Got almost no backing practice in school, had a trainer who would want me to practice backing after driving a 10 hour day, logged as off duty so he could make his training money on my ###, so my ability to back when I went solo was pretty weak. There was more than one time that I ran out of a truck stop after messing up my approach and being unable to correct myself. I am by no means a great backer now, but I have picked up a few things.
    First, for me, the tighter the spot, the better I do. I have more reference points and since there is greater danger of hitting something I am more aware of what I am doing. Go slow and don't be afraid to pull up as much as you can. I can get it between 2 tight trucks easier than I can get it between 2 lines in an empty lot.
    Second, think about how you are going to get your truck in the hole before you start, look and plan. Every back is different, so you have to be able set it up in your head, and not rely on a set way of doing it.
    GOAL, if you think you are going to hit something, you probably will. For all I see people saying to GOAL, in practice, I can probably count the number of times I have seen drivers actually do it on both hands. When I started I needed to see what was going on from the outside, to be able to understand what I was seeing in my mirrors.
    Lastly, find an empty place and practice until you can move the truck in reverse the way you want it to go without thinking about it. Most of the backs I blew starting out was because I was turning the wheel the wrong way, then trying to correct it. You need to practice until you don't have to think about it.
    I hope this helps, this is just my experience, limited as it is. Good luck and be safe.
    CAXPT, MJ1657 and Red Hot Mess Thank this.
  10. Rugerfan
    Rugerfan Road Train Member
    7,625
    38,667
    May 3, 2011
    Redding,CA
    i have about the same experience level(3months) and i have the same problem as the OP where when im following the trailer around in a tight spot i run out of room messes me up more times than i can count
  11. pilottravel2002
    pilottravel2002 Medium Load Member
    688
    156
    May 25, 2011
    Tucson,az
    its just matter of practice and patience,takes time but is not really hard,and remember get out and look,be safe.
    Red Hot Mess and 58Skylane Thank this.
