Time for a tuneup??
Discussion in 'Trucks [ Eighteen Wheelers ]' started by The blue guy, Mar 5, 2015.
  1. The blue guy
    The blue guy Light Load Member
    83
    4
    Jan 4, 2015
    Its way over due, but its time for a tuneup. 2004 freightliner century, detroit series 60 12.7. Ddec 5.
    Its really running like #####! It misfires as its rolling, and it seems te best I can do for fuel mileage is 4.0mpg.
    No smoke or Anything like that.
    any thing you can think of why im getting such ###### gas mileage.
    I will replace my fuel pump and all my injectors too when they do the tuneup.
    What kind of improvement should i expect from a tune up? What are some of your improvements that you saw in yours?
  3. little cat 500
    2,055
    1,100
    Jan 17, 2010
    Abbottstown PA
    prolly the egr acting up but should do a tune up around 100000 miles
    The blue guy Thanks this.
  4. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    How many miles since you ajusted the overhead? The intakes tighten up on those and if it's way overdue, they may be way too tight. I'd check the EGR for issues and run the overhead 1st. Injectors may be a waste of money right now, find the problem first.
  5. The blue guy
    83
    4
    Jan 4, 2015
    The truck has 840k. I just replaced the egr valve 5k miles ago
  6. little cat 500
    2,055
    1,100
    Jan 17, 2010
    Abbottstown PA
    egr's on these motors don't last prolly the valve adjustments tight has it ever been set
  7. The blue guy
    83
    4
    Jan 4, 2015
    Do you mean the valve inside the egr valve? That has to be adjusted if its too tight?
  8. Prom Night Dumpster Baby
    Prom Night Dumpster Baby Medium Load Member
    646
    473
    Jan 12, 2012
    Bug Tussle, TN
    To be nit picky, it's the bridges you adjust, not the valves themselves.
  9. GrapeApe
    2,215
    2,211
    Jan 7, 2013
    Not to be picky, but S60's don't have valve bridges, each valve has it's own adjusting screw in the rockers. :)
  10. Righand81
    Righand81 Bobtail Member
    7
    4
    Feb 28, 2015
    South arkansas
    Grape you took the words out of my mouth!
  11. 1johnb
    1johnb Medium Load Member
    542
    405
    Jun 13, 2012
    New Paris Ohio
    How many bridges have you adjusted on a sixty series?
    The over head on a detroit is the most difficult thing to do on one. In comparison with cat & Cummins. No experience on the Mercedes or vulvas I got lucky and didn't have the shims to set up the compression brake. It went to the dealer.
