Time Management
Discussion in 'Questions From New Drivers' started by Dave_AL, Aug 14, 2011.
  1. Dave_AL
    Dave_AL Light Load Member
    155
    106
    Aug 9, 2011
    AL
    What tips or tricks would you give for the most effective time management on the road in terms of ensuring you can run tight loads with none late, maybe avoiding (as much as possible) restarts, whatever?
    What have you learned from all your experience that keeps you running, maximizes your miles and keeps your DM/FM happy with you?
    Thanks.
  3. Ridgerunner665
    Ridgerunner665 Road Train Member
    2,129
    1,037
    Apr 27, 2009
    When frieght (loads) is plentiful...use no more than 8.75 hours on duty per day.
    When freight is slow...run as hard as you can...by the time you need a restart, the lack of freight usually catches up with you.
    Sounds backwards...but its not.
  4. DirtyBob
    DirtyBob Road Train Member
    1,913
    1,628
    Sep 2, 2010
    Indiana
    Leave the door closed.
    Lonesome Thanks this.
  5. Mdbluecrab
    Mdbluecrab <b>Crusty Crab</b>
    292
    301
    Feb 4, 2010
    White Plains, Maryland
    Sounds like a Smokey looking to find ways to check a drivers log and get the inside scoop.
    If you're a driver, you'll figure it out for yourself and if you're the DOT, I've got nothing else to say.
    Have a nice day :)
  6. Bucktrucker
    Bucktrucker Medium Load Member
    453
    148
    Dec 10, 2008
    ON THE ROAD SOMEWHERE
    I run as hard as i can .... Max my hours every day then take a restart and start over. AT 8.75 x 7 = 61.25 Which is 8.75 hours a day for seven days i could only run 61.25 hours. If i max out every day in 5 days = 70 hrs i would take a restart now im at 6.5 days 5 days running and 1 1/2 days for restart and have used 70 and still have the rest of the seventh day to run so i run the remainder 12 of the seventh day and at the end of the seventh day i have ran a total 82 hours in seven days compared to the 61.25 if i would have only used the 8.75 a day. just how i do it some people dont like to run that hard and can still make good money and keep there dm happy. And some people dont like to sit and take a restart so you will have to find out what fits your way of running.
    HD_Renegade Thanks this.
  7. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,733
    Apr 18, 2010
    Tennessee
    How do you do that when you have a 650 mile run you have to deliver tomorrow?
    Know your recap and know how to do ETA's. Know how to maximize your logbook. Plan your breaks with your trip planning, knowing where you will stop and how long. The most important part is to maintain good communication and a healthy relationship with your dispatcher. The rest will come.
    Tazz Thanks this.
  8. Tazz
    Tazz Road Train Member
    2,821
    1,133
    Oct 25, 2009
    Lynchburg,Tn
    Yeah cuz drivers are so good at out smarting them:biggrin_25526:
    OP do the loads you legally can. Don't whine when they suck we all get a crappy azzed load time to time. As above keep that left door closed, shut off the rambo machine worrying about cops scales or seat covers.........
    Just do your job in an orderly, legal, proficient manner and the money will be there at the end.
  9. Dave_AL
    155
    106
    Aug 9, 2011
    AL
    I didn't ask for illegal ways, bro. Just advice. It's best sometimes to not be so paranoid. Somehow, I picture a driver parked somewhere, peeking out from behind the curtains and constantly scanning the parking lot.
  10. Dave_AL
    155
    106
    Aug 9, 2011
    AL
    First, thanks to everyone who has answered. CondoCruiser touched on my main reason for asking -
    Planning. Before, I thought I was doing it right but, looking back, I know I wasn't. I know I wasn't using my hours (Legally!) to my advantage. My qualcomm gave me fuel stops and destination times and I stayed with those - but I was (and still am) not experienced. And I know there has to be tricks - such as using only certain numbers of hours each day rather than just running your clock out - that aren't generally known by new drivers or taught in the schools.
    I'm about to start a thread on maximizing fuel efficiency, so I hope nobody thinks I'm undercover EPA or DoE or even.... OPEC.
    son n law Thanks this.
  11. roadkill4512
    roadkill4512 Medium Load Member
    396
    241
    May 9, 2008
    Lancaster,PA
    If you're looking to make as much money as you can you run as hard as the law allows and don't limit yourself to 8, 8.5, 9 hrs/day. That strategy may allow you to run for weeks on end without a restart but you make more money quicker if you exhaust all 11 hours or close to it every day, take your restart and then roll hard again.
    The other thing is communicate well with your fleet manager. Let them know when you expect to be empty and how many hours you'll have left at that time. If you are running ahead of schedule call the receiver and see if they'll take you early, often times they will. If you don't mind sleeping at the receiver you can arrive the night before. This will help you in two ways: first, you can be first in line to be unloaded provided they take first come,first serve.. and second you can delay starting your 14 hour day. You must show 15 minutes unload time on your logs. So regardless of how long you were there, start your log book 15 minutes prior to sending your unloaded call.
    Also trip plan so that you drive through congested cities at offpeak times. If you're taking a load from Columbus to Milwaukee you must drive through Chicago. If at all possible you plan it so you go through Chicago between 2300 and 0500, that will ensure you don't sit in a stop and crawl nightmare for hours, Same goes for NYC, Dallas, Atlanta. LA traffic is almost always bad but your best bet there is from 2300 to 0300.
    Dave_AL, venne, johnday and 3 others Thank this.
