Tips for backing.
Discussion in 'Canadian Truckers Forum' started by kendt, Jul 23, 2015.
  1. kendt
    kendt Bobtail Member
    45
    6
    Jan 22, 2015
    I had my 2nd lesson today (of actual driving). I was backing a tractor and trailer in a spot, approaching from 90 deg. Lining my tractor drive tires with the spot and turning hard right. The part I found hard was knowing how long to stay in the turn to position the truck properly for the back up.My instructor was not offering any tips on how to know when you've held the turn long enough.Can anyone offer any pointers or tricks you've picked up.
    Thanks for any advice.
  3. kendt
    45
    6
    Jan 22, 2015
    I realize I may not have described it correctly since there are other situations for backing 90 deg. I am approaching from 90 deg turning hard right and then turning hard left to straighten the truck inline with the spot. I was not staying in the turn long enough and ended up not centered well with the spot.
  4. nate980
    nate980 Road Train Member
    2,020
    5,225
    Dec 23, 2010
    Langley BC
    Honestly practice is the key for getting better. Different rigs/trailers turn differently so it just comes down to time behind the wheel in my opinion.
  5. kendt
    45
    6
    Jan 22, 2015
    I kinda figured as much but thought i'd ask.I didnt do so bad with just normal driving but def struggled with the whole backing up thing.
  6. kendt
    45
    6
    Jan 22, 2015
    I did much better today. I watched some videos last night and picked up a couple of mistakes a was making so that helped.Still a long way to go but I was not anywhere near as frustrated at then end of the lesson.
  7. KB3MMX
    KB3MMX Road Train Member
    3,075
    2,596
    Dec 29, 2014
    Orrstown, PA
    One good tip is to set yourself up as good as possible before beginning. It makes it quicker and easier.
    Each tractor and trailer steers different, so the way you set yourself up before backing will be a little different in every truck.
  8. Straight Stacks
    Straight Stacks Paper Cha$er
    2,930
    20,768
    Jul 18, 2015
    Alabama Gulf Coast
    Tip: Don't take off another drivers side mirror.
    CanadianVaquero and pmcfee Thank this.
  9. kendt
    45
    6
    Jan 22, 2015
    Is that supposed to be helpful ?
    Ontario_boy Thanks this.
  10. tucker
    tucker Road Train Member
    12,647
    40,424
    Jun 13, 2008
    IN
    That was great advice, don't hit a mirror.
    I'm pretty good at backing up, every spot requires a different set up, I think. I can't explain it.
    Backing takes practice, when you get your own truck,,, practice all the time in bigger truck stops. Anyone can drive forwards.
    Most drivers can't back up anyways, they keep circling the truck stop, waiting for the elusive pull thru spot to open, when there are dozens of back in spots available.
    Relax, you'll get it. Just don't hit a side mirror !!
    O.Henry and Straight Stacks Thank this.
  11. jerezxp7
    jerezxp7 Medium Load Member
    569
    469
    Apr 4, 2007
    oregon
    There is a delay between when you stop turning and when your trailer reacts so if your still turning when your trailer reaches the spot , you have waited to long, it's somewhat difficult to explain but you will learn it with practice. I also agree take your time to set yourself up right a good start can make things easier. Try to start corrective steering slightly before you think you need to and see the difference it feels weird at first because you feel like you should still be turning the wheel but after the delay the trailer is in position. Practice practice practice
    Keithdabarber and O.Henry Thank this.
