Tips for shimming slack adjusters
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Dino soar, Sep 21, 2019.
  1. Dino soar
    Dino soar Road Train Member
    4,815
    27,071
    Dec 8, 2017
    I'm putting new slack adjusters on my truck and I seem to be having a hard time shimming them so they are under .060.
    The kit gives me larger washers to put behind the slack adjuster and smaller washers to put in front of the circlip. I've tried different combinations and using the fat circlip or trying to stack more washers on and use to the thin circlip, but I can't seem to make them that snug.
    I am checking them with a dial gauge indicator.
    Any ideas?
  3. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    More washers! Meritor sells assortment bags of them.
    Oxbow, Intothesunset and Dino soar Thank this.
  4. Working2party
    Working2party Medium Load Member
    608
    729
    Feb 10, 2018
    Kansas
    A washer is a washer, Reuse the old ones also, just clean them up. The older trucks it was a big deal to shim under the slack to where it’s centered for the chamber rod. The newer parts have been built with better techniques. So it’s more standard.
    In your case put enough washers on to where the slack is centered. Stack enough on the outsides to where you just get the snap ring on. Take one small washer out and it’s there.
  5. Dino soar
    4,815
    27,071
    Dec 8, 2017
    They have an assortment that is different sizes than what they give you in the camshaft repair kit?
    Intothesunset Thanks this.
  6. Dino soar
    4,815
    27,071
    Dec 8, 2017
    The problem is that in the camshaft repair kit they only give me two different size washers. One for the back of the slack adjuster and one for the front. They give me a bunch of them but there are only two sizes.
    It seems like whatever combination I put together in there I just can't get enough slack out or I can't get the snap ring on.
  7. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    No need to use a dial indicator, they are not that critical, like said above usually with a combination of the new ones that come with the cam bushings and the old ones, a guy can get them close enough.
    Working2party, mhyn, Dino soar and 2 others Thank this.
