Tips for straight trucks steep grades
Discussion in 'Questions From New Drivers' started by Kschwing51, Jan 29, 2018.
  1. Kschwing51
    Kschwing51 Bobtail Member
    5
    Jan 29, 2018
    looking for tips driving my straight truck on 80 west through Wyoming to California. Been using low gears w the engine brake but rpms still get very high. Don’t want to use my brakes too much and smoke them out. Any tips?
  3. Allow Me.
    10,649
    12,147
    May 28, 2009
    Rancho Mirage, Ca.
    What kind of straight truck ? Single screw or ? Weight ? Tranny ? With your regular 18 wheeler, descending a 6% 78K , for instance, you can go down without touching the brakes, in the proper gear with the jake. (and proper speed)
  4. Kschwing51
    5
    Jan 29, 2018
    28 ft moving truck. Single axle. 34,000lbs fully loaded. Been descending in at 35 mph in low gear but after awhile the jake won’t keep it from accelerating
  5. Zigzag777
    Zigzag777 Medium Load Member
    460
    513
    Mar 25, 2013
    Down Yonder
    If it less than a 400 HP engine, might not have enough compression to hold your weight. Some medium duty trucks have lower HP ratings, usual engine size is less than a 13 liter block, might have just an “exhaust brake”, not an actual Jake Engine Brake. Sounds like that might be the problem.
    From the Jacobs Vehicle Systems website:
    In it's simplest description, the Jacobs Engine Brake converts a diesel engine into an air compressor. All other factors being equal, the larger the engine displacement, the more powerful an air compressor it can make, and the higher the retarding performance.
    RoadRooster, Kschwing51 and x1Heavy Thank this.
  6. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,130
    Mar 5, 2016
    White County, Arkansas
    Gear down. 35 may be too fast.
    IF the engine fails to hold her while Jaking, you may have hit a steeper section. Use your brake to firmly and slow down to about two or three gears down. Reestablish the jake.
    Never mind the RPMs too much, Jakes will give you more braking towards the red line provided you have adequate oil pressure, adequate but not overhot oil temp and a overcooked pyro.
    There are some mountains I don't go down at 35. 17 or so is more like it.
    We don't go by MPH here obviously. So, slow down to where the jake will hold her at a constant speed all the way down. That is a perfect run.
    Keithdabarber and Kschwing51 Thank this.
  7. Kschwing51
    5
    Jan 29, 2018
    Thank you both for the responses. I was worried about going below 20 mph thinking it may be a hazard for other trucks coming down. Glad to know I can slow down
    Keithdabarber Thanks this.
  8. Ridgeline
    22,211
    114,058
    You don't know how to control the truck, using the engine brake (which more likely you have an exhaust brake on that truck) and gearing down won't do it, you have to use your brakes.
    Don't be afraid to use the brakes, they are there for a reason. Nothing like hitting 60 mph going downhill and hitting something.
    here is a good thread about stab braking.
    Stab or Controlled Breaking Which Best/Fastest ?
    Kschwing51 Thanks this.
  9. jammer910Z
    jammer910Z Road Train Member
    2,446
    6,521
    May 28, 2015
    I know it's too late now, but was it an automatic, a manual tran?
    Also, were the brakes properly adjusted?
    If this is a rental, and you're not familiar with the equipment you won't know to look for these things.
    34k is not that heavy for the Wyo grades if you're brakes are properly adjusted and you drop on or two with the Jacobs engaged.
    Next time you're in this position, and not certain, find a truckstop and look for an old timer ( one not wearing flip flops and pajama pants will be your first clue... jeans, boots, and a coffee mug will be a good tell) and ASK him to give a quick look.
    Any good driver worth their salt would look for someone that had the grit to admit they needed help.
    I WOULD HELP, AND I HAVE.
    I've helped older folks in RVs , people in Uhauls, Coaches, etc.
    We have knowledge... ask for it in real time.
    Don't be embarrassed.
  10. Kschwing51
    5
    Jan 29, 2018
    Not too late I’m on my way to Utah. It’s auto trans. Just had a pm on the truck so brakes better be correct. First time out west in winter def a rookie mtn driver. Just wanna be ready for park city and Tahoe areas
  11. Allow Me.
    10,649
    12,147
    May 28, 2009
    Rancho Mirage, Ca.
    At 34k gross on two axles (28') you're almost half of normal 18 wheeler on 5 axles, right ? Most 6% downgrades say "truck 25 mph" . Don't be too much in a hurry to descend any grade in a truck.
    jammer910Z and Kschwing51 Thank this.
