Tips on driving a stinger
Discussion in 'Car Hauler and Auto Carrier Trucking Forum' started by justcarhaulin, Feb 24, 2016.
  1. justcarhaulin
    justcarhaulin Light Load Member
    153
    238
    Jul 20, 2015
    Hallo car haulers. Am movin on up to a stinger from high mount trailer. I picked it up last from cottrell and drove empty all the way to the east coast. The hardest thing ive had to get used to is the headrack. I have not loaded cars on it yet as am still working on registration and stuff. I surely could could use some tips on driving, loading or how you can tell the light is green by looking at the reflection on the hood etc. Thank you
  3. Hammer166
    7,453
    26,982
    Aug 18, 2007
    ~8600+' and loving it!
    You'll have to learn to sweep your corners or you'll catch a car in the pinch. Don't be afraid to stretch out in tight spots to avoid this. Dips are now your mortal enemy.
    Depending on what trailer you have, learn the flexibility in your loading multi stop loads.
    And you'll get to where you feel naked without something over the hood.
    canadianredneck, Terry270 and SLANT6 Thank this.
  4. NuCar Carrier
    NuCar Carrier Light Load Member
    132
    314
    Jan 23, 2016
    Everything Hammer 166 said.
    Your turning clearance between tractor and trailer has to be at least the length from elbow to hand for upper units. Obviously you need more space for upper units. Do a check turn after loading to ck your clearance.
    If you have to turn where there is a dip, get out and raise decks or slide them to get more clearance or don't go there, you can total a car faster than you can say 'son of #####, wtf now!'
    You won't be doing any tight freight hauler turns, some stingers have stops and once you hit them you're done turning. I have seen drivers that drove into the ditch because of this. Also those $300 SS gravel guards 'batwings' get crunched.
    With some high rail stingers you can unload all the upper units on the tractor under the ones on the trailer or unload the whole truck under the upper rear deck. Lots of tricky stuff you'll figure out that I sometimes wonder is worth the time it takes to figure out.
  5. SLANT6
    SLANT6 Road Train Member
    1,094
    1,376
    Dec 3, 2012
    The Nut House
    Did you drive for NuCar back in the day?
  6. NuCar Carrier
    132
    314
    Jan 23, 2016
    Yes I did. Owner / Operator out of Wayne, Mi 1983 - 90 when E&L got the traffic and made a mess of it.
