Tire Black
Discussion in 'Trucks [ Eighteen Wheelers ]' started by true blue, Oct 11, 2014.
  1. true blue
    true blue Medium Load Member
    305
    232
    Jul 13, 2011
    Harrisburg, NC
    Anyone have a recommendation for blackening tires? I have a drive tire that got yellow paint on it, used some cleaner that the shipper had to clean it off and now my tire is a grayish color where I rubbed out the paint. I washed them several times with Simple Green and a stiff brush and then used some old Tire Wet that i'd had laying around awhile. It normally has a cherry scent, but this stuff is a few years old and doesn't smell so good.
  3. skellr
    skellr Road Train Member
    8,735
    12,187
    Jul 17, 2011
    The Village, Portmeirion
    Ajax powerded cleanser and a stiff brush usually does a good job. It uses quartz and bleach.
  4. rollin coal
    rollin coal Road Train Member
    13,465
    27,472
    Mar 29, 2008
    TN
    Brake parts cleaner might work. Spray and scrub.
  5. Pedigreed Bulldog
    7,737
    14,422
    May 7, 2011
    I'd be more concerned about the chemicals in the cleaner and the effect they had on the rubber to give it that grayish color than I would have ever been about a little yellow paint. You don't want to intentionally put anything on the tires that will degrade the rubber. Brake cleaner is a bad idea, too...usually says NOT to spray it onto rubber components right there on the label.
    Richter and Hardlyevr Thank this.
  6. allisonisatranny
    allisonisatranny Light Load Member
    188
    131
    Oct 6, 2014
  7. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    You beat me to it!!
  8. rollin coal
    13,465
    27,472
    Mar 29, 2008
    TN
    I wouldn't the think wiping the sidewall of the tire with some brake parts cleaner would destroy the integrity of the tire. Now if you were to leave it soaking in a pool of brake parts cleaner, if it didn't evaporate, yeah that might eat up a tire. I degrease the inside of my steer rims every time I grease the kingpins with break parts cleaner. If any grease got on the sidewall I always wipe it off with it. Never been a problem. If he's worried about it he could use tire lubricant to restore the rubber. It always cleans and restores along with making it easier to mount tires.
  9. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
    What we used when I worked at a tire shop...
  10. savage02
    savage02 Light Load Member
    163
    50
    Dec 21, 2007
    Upstate, NY
    Diesel fuel on a rag will work as good as anything. Will take the paint right off.
    true blue Thanks this.
  11. true blue
    305
    232
    Jul 13, 2011
    Harrisburg, NC
    Well, guys, I appreciate all your input. Found out, after consulting with BF Goodrich and my tire dealer, a few intersting things that will help us all.
    1. Tires need to breathe, so anything that suffocates or seals the sidewall is not good for the tire.
    2. Anything with silicone is not recommended and will void the warranty on the tire.
    3. Tire Wet and Armorall are silicone based, thereby sealing the sidewall and voiding any warranties.
    So, I'd say, since tires are a petroleum based product, I'd lean towards savage02's recommendation of using diesel fuel.
